Rims for Legacy GT - Does it Fit?
JAU
I am new to cars. Can someone pleaes let me know if these specs for rims will fit a legacy please?
This is what the website says:
18 -7.5J,OFF+48,PCD100/5H
If it does, is there any disadvantage or advantage to these specs? I have read xenonk's sticky. But be glad to hear more.
Thanks. :)
Guest *Jedimaster*
The answer to the question is:
18 -7.5J,OFF+48,PCD100/5H 18 -7.5J,OFF+48,PCD100/5H 18 -7.5J,OFF+48,PCD100/5H 18 -7.5J,OFF+48,PCD100/5H .
Furthermore,
18 -7.5J,OFF+48,PCD100/5H 18 -7.5J,OFF+48,PCD100/5H 18 -7.5J,OFF+48,PCD100/5H 18 -7.5J,OFF+48,PCD100/5H 18 -7.5J,OFF+48,PCD100/5H 18 -7.5J,OFF+48,PCD100/5H 18 -7.5J,OFF+48,PCD100/5H
So you might be inclined to think:
But really:
18 -7.5J,OFF+48,PCD100/5H !!!!
So in conclusion,
18 -7.5J,OFF+48,PCD100/5H 18 -7.5J,OFF+48,PCD100/5H 18 -7.5J,OFF+48,PCD100/5H 18 -7.5J,OFF+48,PCD100/5H 18 -7.5J,OFF+48,PCD100/5H 18 -7.5J,OFF+48,PCD100/5H 18 -7.5J,OFF+48,PCD100/5H 18 -7.5J,OFF+48,PCD100/5H
Furthermore,
But really:
So in conclusion,
So (Good)Will (Hunting),...why have you been mopping the floors when you could've been working for the NSA or curing Cancer??
:lol:
Just make sure hub bore is 56.1mm.
To clarify; make sure the hub bore is no smaller than 56mm or the wheel won't fit over the hub. If the hole is bigger, you should be using hub-centric rings to assure that the wheels are perfectly centered on the hub.
