sikend667 Posted April 2, 2013 Share Posted April 2, 2013 so the car started throwing a p0400 intermittently. it will stay on for a few days and then mysteriously dissapear for about a day then come back. i have disassembled, cleaned and reassembled the egr also replaced the vacuum valve (circled below) any other suggestions or possible loose wires i should be looking for? http://i904.photobucket.com/albums/ac242/sikend667/egr_zps4468a67c.jpg Link to comment Share on other sites More sharing options...
Osei Posted April 2, 2013 Share Posted April 2, 2013 Nice clean engine bay. There is a small metal pipe that connects to a rubber hose then to the EGR. Make sure it is free flowing. Also check the hose that goes to the BPT and the small hole in the BPT itself. Lastly, check operation of the EGR solenoid. Just connect green connectors under driver dash. All solenoids and fans will cycle. You may have to remove from manifold to be sure it's working. O. Link to comment Share on other sites More sharing options...
sikend667 Posted April 2, 2013 Author Share Posted April 2, 2013 what i cant seem to find is the solenoid itself. i know on the imprezas its basicly under the EGR it is located in a different place on the legacy? did just have the motor out and replaced all those hoses when i worked on the tranny Link to comment Share on other sites More sharing options...
Osei Posted April 2, 2013 Share Posted April 2, 2013 Follow the line from the Egr. It is tucked away on the passenger side under the TB. 12mm bolt. O. Link to comment Share on other sites More sharing options...
sikend667 Posted April 2, 2013 Author Share Posted April 2, 2013 thank you sir im going to go dig at it on my linch break. is there an easy way to clean these or should i just toss it and get a new one? the car was a high desert car so everything was caked with about 3 inches of dust and grime when i got it so im sure the solenoid is clogged. when i cleaned out the valve itself it was pretty bad. Link to comment Share on other sites More sharing options...
Osei Posted April 3, 2013 Share Posted April 3, 2013 Can't throw it out. Not sure how yours is attached, but the metal extension from the exh. manifold is swaged on. Some units have a 12mm bolt securing it.( My 96 DOHC is swaged, while the 97 2.2 was bolted). Coat hanger and alternating heat with water into the pipe finally worked for me. If you don't get a complete pass through with the hanger, its blocked. O. Link to comment Share on other sites More sharing options...
sikend667 Posted April 3, 2013 Author Share Posted April 3, 2013 piping is all cleaned out used a drill auger (kinda like a pipe snake) thats why im starting to suspect the solenoid. Link to comment Share on other sites More sharing options...
Osei Posted April 3, 2013 Share Posted April 3, 2013 Here is link for FSM. http://www.main.experiencetherave.com/subaru_manual_scans/ O. Link to comment Share on other sites More sharing options...
sikend667 Posted April 3, 2013 Author Share Posted April 3, 2013 thanks man will read thru all that this weekend..... i hate emissions..... Link to comment Share on other sites More sharing options...
Hemingway Posted April 3, 2013 Share Posted April 3, 2013 Wow - great looking engine compartment - I wish my bay was that clean! Nice job! Suggestion: hard to tell from the pic, but it looks like the driver side spark plug wires (right side of coil in pic, #2 and #4) may be binding / kinked and touching the manifold. I would turn the wires 90 degrees to relieve the bind and move the wires up and away from a hot manifold. What make and spec is that front swaybar? Link to comment Share on other sites More sharing options...
Osei Posted April 3, 2013 Share Posted April 3, 2013 ......What make and spec is that front swaybar? Strut Bar. O. Link to comment Share on other sites More sharing options...
Hemingway Posted April 4, 2013 Share Posted April 4, 2013 Strut bar ... right, thanks. Link to comment Share on other sites More sharing options...
sikend667 Posted April 4, 2013 Author Share Posted April 4, 2013 not my engine bay lol just a reference pic. mines emarrasingly dirty so i didnt dare post a pic of it for example Link to comment Share on other sites More sharing options...
twisty Posted April 4, 2013 Share Posted April 4, 2013 Suggestion: hard to tell from the pic, but it looks like the driver side spark plug wires (right side of coil in pic, #2 and #4) may be binding / kinked and touching the manifold. I would turn the wires 90 degrees to relieve the bind and move the wires up and away from a hot manifold. thats where the stock clips hold the cables. when i did my MSD mod i had to go to the 90 deg cables, it bothered me to put them so close to the manifold as well, but after looking at pretty much every stock 97-99 in the pick n pulls they were all the same way so i figured it would work. Link to comment Share on other sites More sharing options...
