morris8809 Posted April 1, 2013 Share Posted April 1, 2013 New member here, just looking for some pointers on where the noise my car is making may be coming from. First here are some videos showing the noise. 2.5l N/A 60.5k miles http://s446.photobucket.com/user/morris8809/media/VID_20130328_162133_zpse385a464.mp4.html http://s446.photobucket.com/user/morris8809/media/VID_20130328_161942_zpsc2b914f4.mp4.html http://s446.photobucket.com/user/morris8809/media/VID_20130328_161558_zps3cb58290.mp4.html The mileage just turned over to 60.5K miles so here is what I have done to the car so far: Oil change (using penz ultra 5w-30 since I purchased the car in sept-2012) (used Honda filter) Transmission drain and fill using Honda fluid and new filter Both diffs fluid changed timing belt & all idlers and tensioner using oem parts brake fluid flushed coolant flushed using Honda coolant with conditioner. The sound almost sounds like it is coming from the flywheel area at the rear of the motor but it is difficult to tell. I am just trying to make sure it is nothing to be worried about. Link to comment Share on other sites More sharing options...
ResidentRedneck Posted April 5, 2013 Share Posted April 5, 2013 ugh.... that sounds bad. drain the oil and put a heavier weight in there and see what it does. i dont know much about subaru engines so i dont know how heavy you can go, but at least 10w40. (remember with oils, the second number is the viscosity, so 10w30 is not a heavier oil) Link to comment Share on other sites More sharing options...
GEE-OTTO Posted April 6, 2013 Share Posted April 6, 2013 That is not good, have power levels changed any? Oil usage increased ? Link to comment Share on other sites More sharing options...
morris8809 Posted April 7, 2013 Author Share Posted April 7, 2013 No change. The noise has been there for the past 5-8k miles. It started to become more noticeable as temps cooled in winter and now that temps are going up it is not as bad. Tuesday a dealer will be taking a look into the issue to see what is going on. I have been running pens ultra 5w-30 and wix filter until last change (400 miles ago) when I switched to Subaru blue filter. I have never seen any metal flakes or particles in the used oil and the engine does not consume any at all between changes. Using a stethoscope the sound seems to be coming more from the valve area and not the cylinder or crank area. Link to comment Share on other sites More sharing options...
GEE-OTTO Posted April 7, 2013 Share Posted April 7, 2013 Yeah could be a simple issue of valve lashing or maybe something in the rocker assembly is worn/breaking.. Link to comment Share on other sites More sharing options...
morris8809 Posted April 9, 2013 Author Share Posted April 9, 2013 Both dealerships I took it to said that it is wrist pin worn/knocking and will need to rebuild or replace the engine... Link to comment Share on other sites More sharing options...
ShrinerMonkey Posted April 10, 2013 Share Posted April 10, 2013 Isn't that just EJ25 piston slap? Might not be a big deal. http://www.thetruthaboutcars.com/2012/11/piston-slap-subaru-piston-slap/ Link to comment Share on other sites More sharing options...
morris8809 Posted April 10, 2013 Author Share Posted April 10, 2013 Most likely going to just drive it, keep it maintained and when it goes, it goes. Once that time comes ill stick a new or rebuilt motor in it and drive it some more. I really dont think it is anything to bad as its had the noise for over 8k miles. If it were the main bearing or wrist pin it should not have lasted this long. Link to comment Share on other sites More sharing options...
ShrinerMonkey Posted April 10, 2013 Share Posted April 10, 2013 Most likely going to just drive it, keep it maintained and when it goes, it goes. Once that time comes ill stick a new or rebuilt motor in it and drive it some more. I really dont think it is anything to bad as its had the noise for over 8k miles. If it were the main bearing or wrist pin it should not have lasted this long. If it has been making that noise for 8k miles then that is most likely piston slap. You can try using a thicker oil to help quiet it down but I wouldn't worry about it. Link to comment Share on other sites More sharing options...
4doors4hp Posted April 24, 2013 Share Posted April 24, 2013 its not that bad. youre fine. just do an oil change, and im assuming your car is cold yet? my car just his 133k and sounds similar, a little quieter. and i just rebuilt the motor last month. sounds like valve ticking.. Link to comment Share on other sites More sharing options...
K19DLA Posted May 3, 2019 Share Posted May 3, 2019 Hi, Any update on this one? I have exactly the same issue/sound Link to comment Share on other sites More sharing options...
