05pearl Posted April 2, 2013 Share Posted April 2, 2013 I can log fine, but the ECU stops transmitting data in the middle of the WOT pull around 4.5k rpm. From what I'm reading I'm not the only one to have this problem either. I don't think that even a reputable tuner would be able to solve this issue quickly. Plus the nearest brick and mortar tuning shop is 100+ miles away. Instead of using Vag-Com, go to Tactrix.com and buy their hardware. Then pay $150 to Infamous1 (etuner on this site) to set you up with a good e-tune. Also, post where you are located and maybe a member with a Tactrix openport can help you out by logging for you... Link to comment Share on other sites More sharing options...
RallyMachine Posted April 2, 2013 Author Share Posted April 2, 2013 I have previously tried logging with my friend's Tactrix who uses it for his 04 STI without problems yet we had the same issue I am having with the Vag-Com on my car only. Link to comment Share on other sites More sharing options...
05pearl Posted April 2, 2013 Share Posted April 2, 2013 Ok, I see now. Sorry, I misunderstood. It seems like you are going to need/want a tune eventually correct? If so, you may still want to contact Infamous1 for an e-tune. He may be able to assist you with your logging issue since he should be uber familiar with all the potential problems with logging/connecting properly to the ECU. He was always pretty patient/understanding as I recall. Link to comment Share on other sites More sharing options...
iNVAR Posted April 2, 2013 Share Posted April 2, 2013 before shelling out more money for a tactrix cable, read cone_killer's thread. he did that already, no luck. other people have had luck by switching cables, some haven't. so hit or miss. if your friend's tactrix definitely worked, I guess that's a safe bet then. Link to comment Share on other sites More sharing options...
RallyMachine Posted April 2, 2013 Author Share Posted April 2, 2013 Ok, I see now. Sorry, I misunderstood. It seems like you are going to need/want a tune eventually correct? If so, you may still want to contact Infamous1 for an e-tune. He may be able to assist you with your logging issue since he should be uber familiar with all the potential problems with logging/connecting properly to the ECU. He was always pretty patient/understanding as I recall. I was planning on getting an e-tune from him so I guess I'll shoot him a PM and get things rolling and see if he has any solutions. before shelling out more money for a tactrix cable, read cone_killer's thread. he did that already, no luck. other people have had luck by switching cables, some haven't. so hit or miss. if your friend's tactrix definitely worked, I guess that's a safe bet then. Sorry for the confusion, but my friends Tactrix did NOT work with my car despite the fact that he uses it to log his car quite often. Link to comment Share on other sites More sharing options...
RallyMachine Posted April 2, 2013 Author Share Posted April 2, 2013 Does anyone see a benefit to re-grounding my OBD port? (Friend suggestion) Link to comment Share on other sites More sharing options...
05pearl Posted April 2, 2013 Share Posted April 2, 2013 It's been so long since I logged, I forgot if there is a way to adjust logging speed. If there is, you may try lowering the data collection rate to see if you can get a full log that way. Link to comment Share on other sites More sharing options...
RallyMachine Posted April 2, 2013 Author Share Posted April 2, 2013 Yeah I changed the bit rate in my control panel devices to 4800 to match the speed of the ecu. I think it's more an issue of the data transmission rather than collection unfortunately... Link to comment Share on other sites More sharing options...
05pearl Posted April 2, 2013 Share Posted April 2, 2013 Yeah I changed the bit rate in my control panel devices to 4800 to match the speed of the ecu. I think it's more an issue of the data transmission rather than collection unfortunately... Is that the lowest speed? If not, try it at the lowest speed. Link to comment Share on other sites More sharing options...
iNVAR Posted April 2, 2013 Share Posted April 2, 2013 what drivers are you using? Link to comment Share on other sites More sharing options...
RallyMachine Posted April 2, 2013 Author Share Posted April 2, 2013 Is that the lowest speed? If not, try it at the lowest speed. I'll give it a try tonight. what drivers are you using? Whatever downloaded when I plugged it in. (Win7 32-bit OS) Link to comment Share on other sites More sharing options...
iNVAR Posted April 2, 2013 Share Posted April 2, 2013 replace them. I'm link you when I get home from work later. worth a shot Link to comment Share on other sites More sharing options...
RallyMachine Posted April 3, 2013 Author Share Posted April 3, 2013 Well I successfully pulled the .hex file from the ecu tonight...not quite sure what to do with it, but it's progress! When it saved to my hard drive, there wasn't any extension on it though and it just read file type: file Link to comment Share on other sites More sharing options...
iNVAR Posted April 3, 2013 Share Posted April 3, 2013 open the HEX in RR ECU Editor and you can see what your map looks like. I'm not sure if posting your map would be allowed though being that it was professionally tuned. You can post individual tables by doing screenshots of them, but not the entire map as a HEX file. Also, drivers, try these: http://www.crimetank.com/misc/CDM20602.zip http://legacygt.com/forums/showthread.php/does-look-learning-view-thanks-182174.html?p=3809269&highlight=drivers#post3809269 for a very thorough process of removing existing instances of previous drivers. Link to comment Share on other sites More sharing options...
RallyMachine Posted April 3, 2013 Author Share Posted April 3, 2013 Well I went out and did several pulls tonight, a couple WOT and a couple NOT full throttle, all to the rev limiter. Same result:spin: This is just a guess, but it seems as though the cut out is always right around the time when the engine would be reaching 100% load...not sure if this would have anything to do with it. Link to comment Share on other sites More sharing options...
05pearl Posted April 3, 2013 Share Posted April 3, 2013 If you have lower logging speed all the way, then also try limiting the number of parameters you are logging to the following: Engine Speed (rpm) Engine Load (Direct)* (g/rev) Ignition Timing (degrees) Knock Sum (count) Manifold Rel. Pressure (psi) 4-byte Mass Air Flow (volts) Mass Air Flow (g/s) Primary Wastegate Duty Cycle (%) Throttle opening angle AFR (if you have wide band) Link to comment Share on other sites More sharing options...
uncle humjaba Posted April 3, 2013 Share Posted April 3, 2013 I had the same problem with my vag-com cable (cuts out at 4500rpm or so). Borrowed a friend's Tactrix 1.3 (not the 2.0), stuck a couple ferrite cores on there and it worked. Obviously, your mileage may vary. Good luck though, I know how frustrating that is. Link to comment Share on other sites More sharing options...
heiche Posted April 4, 2013 Share Posted April 4, 2013 wonder if some of these wot logging issues might be due to an old "noisy" alternator? BtSsm - Android app/Bluetooth adapter. LV, logging, gauges and more. For 05-14 Legacy (GT, 2.5, 3.0, 3.6), 02-14 WRX, 04-14 STi, 04-14 FXT, 05-09 OBXT Link to comment Share on other sites More sharing options...
Cone_Killer Posted April 4, 2013 Share Posted April 4, 2013 ^ I have the same issues with a brand new alternator lol. I still want to replace my battery, even though its perfectly fine... Link to comment Share on other sites More sharing options...
heiche Posted April 4, 2013 Share Posted April 4, 2013 ^ I have the same issues with a brand new alternator lol. I still want to replace my battery, even though its perfectly fine... Ugh! so much for that theory! sounds like you've been through a lot trying to solve this issue. BtSsm - Android app/Bluetooth adapter. LV, logging, gauges and more. For 05-14 Legacy (GT, 2.5, 3.0, 3.6), 02-14 WRX, 04-14 STi, 04-14 FXT, 05-09 OBXT Link to comment Share on other sites More sharing options...
RallyMachine Posted April 4, 2013 Author Share Posted April 4, 2013 Mods please close this thread as my knock is not longer the major issue here. Just wanted to consolidate the logging cut out threads to reduce confusion. For anyone reading this in the future here is the link to the primary logging issue thread: http://legacygt.com/forums/showthread.php/cannot-log-wot-pulls-202559.html Thanks all for the help. Link to comment Share on other sites More sharing options...
iNVAR Posted April 4, 2013 Share Posted April 4, 2013 nooo leave it open. no reason to close it. Link to comment Share on other sites More sharing options...
RallyMachine Posted April 4, 2013 Author Share Posted April 4, 2013 Ok, I guess i'll post back up a full log if/when I get my logging issue solved. Link to comment Share on other sites More sharing options...
RallyMachine Posted April 7, 2013 Author Share Posted April 7, 2013 Well now that I got my logging problem figured out, here are 2 complete pulls I logged. Looks like the minor knock may have been from the electrical noise? A/F learning still looks off though...Complete Pull 1.csvComplete Pull 2.csv Link to comment Share on other sites More sharing options...
iNVAR Posted April 7, 2013 Share Posted April 7, 2013 Wait, how'd you fix your logging problem? edit: n/m, saw your mention about the capacitor. great news! Link to comment Share on other sites More sharing options...
