garygbnj Posted March 26, 2013 Share Posted March 26, 2013 06 lgt mt-stage 2-145k on the odometer, had since new-Intermittent stalling when coming to a stop. Replaced tgv gaskets and all intake manifold gaskets & injector o rings. My mechanic is guessing that the electric motor in the throttle body is sticking and not moving fast enough to stop the stalling. He is suggesting a new throttle body. Will any throttle body, generation 4, be ok? Or does it have to be an 06 model year? He does not think there is any way to "free up the electric motor". Is it advisable to buy a used throttle body? thanks gary Link to comment Share on other sites More sharing options...
06silvarubiLGT Posted March 27, 2013 Share Posted March 27, 2013 Any 05-07 should work. I had same problem with mine. Link to comment Share on other sites More sharing options...
Mrobe10022 Posted April 2, 2013 Share Posted April 2, 2013 I'm having trouble with my car it stalled once, but when I braek the engine shakes and the RPMs drop below the lowest mark on the tach. Any ideas? I took one of the wires off of the battery to clean off the corrosion. Ithink I may need to reset the computer possibily... please help Link to comment Share on other sites More sharing options...
Steve R. Posted April 2, 2013 Share Posted April 2, 2013 Are either of you using a full atmospheric bov? When I got my car, I removed my bypass tube(and plugged it of course) to vent to atmosphere on my stock valve. It got put back on as soon as I got home. It stalled occasionally when stopping, usually after reaching higher rpms. Easy driving thru town (2000-2300 rpm shifts) did not really have problems. Link to comment Share on other sites More sharing options...
garygbnj Posted April 2, 2013 Author Share Posted April 2, 2013 No full atmospheric bov Link to comment Share on other sites More sharing options...
Mrobe10022 Posted April 2, 2013 Share Posted April 2, 2013 I got some carb/ intake cleaner sprayed it down and cleaned the throttle circle thing (sorry, I'm not very techincally inclined when it comes to the proper terminology) it was pretty dirty thick black stuff. Started it back up...... Check engine light came on, BUT the car runs fine now. RPM on the tach seems normal after braking. No shaking or rumblng. I think the check engine light might just be from the valoline throttle cleaner down the intake on accident. In my informal diagnosis: I think the throttle circle thing wasn't closing all the way because it was gummed up screwing up the air to fuel combo; which did not effect the car while driving, but causing it to sputter at stop lights and stop signs. Link to comment Share on other sites More sharing options...
spec.B Dream Posted April 2, 2013 Share Posted April 2, 2013 I've been told that cleaning the throttle body and plate should be standard maintenance along with cleaning the MAF on these cars. My local tuner recommends doing it every oil change. Link to comment Share on other sites More sharing options...
garygbnj Posted April 3, 2013 Author Share Posted April 3, 2013 Injector o rings replaced-one was gouged. Throttle body removed and cleaned. It has only been 2 days but no more stalling. The tach also now settles down asap upon the throttle closing. It used to bounce a bit. I think the problem has been solved. thanks for all of the helpful advice. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted April 14, 2014 Share Posted April 14, 2014 reviving this old thread. I think I am having the same problem. OP, is your car still doing OK since you've removed and cleaned the throttle body? Link to comment Share on other sites More sharing options...
garygbnj Posted April 14, 2014 Author Share Posted April 14, 2014 did ok all winter. Gone down the tubes with the arrival of spring and warm temperature. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted April 15, 2014 Share Posted April 15, 2014 care to elaborate? Link to comment Share on other sites More sharing options...
garygbnj Posted April 15, 2014 Author Share Posted April 15, 2014 As the weather warmed stalling restarted. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted April 15, 2014 Share Posted April 15, 2014 interesting. Did you ever check/change your pcv valve? It may have been bad and made your throttle body dirty again Link to comment Share on other sites More sharing options...
muddy02 Posted April 15, 2014 Share Posted April 15, 2014 sure it's not this? : http://legacygt.com/forums/showthread.php/p2138-throttle-pedal-position-sensor-switch-150344.html It's not about speed, it's about acceleration! Link to comment Share on other sites More sharing options...
garygbnj Posted April 15, 2014 Author Share Posted April 15, 2014 will try thanks Link to comment Share on other sites More sharing options...
frank_ster Posted April 15, 2014 Share Posted April 15, 2014 try an idle relearn .. disconnect battery reconenct let idle in drive ( if auto ) N if mt with everything on let it idel untill the engine reaches temperature.. this is common problem Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
spec.B Dream Posted April 15, 2014 Share Posted April 15, 2014 Can this also be done with a Learning View reset? Sent from my Nexus 4 using Tapatalk Link to comment Share on other sites More sharing options...
garygbnj Posted April 16, 2014 Author Share Posted April 16, 2014 thanks Link to comment Share on other sites More sharing options...
frank_ster Posted April 16, 2014 Share Posted April 16, 2014 Can this also be done with a Learning View reset? Sent from my Nexus 4 using Tapatalk i would think but don't know for sure.. if you are able to tune your car you can raise the initial throttle position in the drive by wire tables. by a tiny bit. keep in mind that every car is slightly different. and the difference i nthe throttle body initial angle in combination with other things some cars will do this worse than others. its why the learning is important. as it warms up the first time after a rest it memorized the throttle position at each given temperature and will use that when you drive your car instead of the predetermined values. Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
