Hemingway Posted March 17, 2013 Share Posted March 17, 2013 While perusing my '98 Legacy owner's manual, I was curious to see a warning about not using the cigarette lighter socket (bottom center dashboard, in front of the transmission shifter) as an 'accessory power outlet.' News to me since I had used it many times to charge a cell phone, GPS, etc. Here is an explanation from a Subaru Insider Info tech release: "In-Dash Cigarette Lighter Usage Some Subaru owner’s manuals state that the in-dash cigarette lighter cannot be used as an accessory power outlet. Fuji Heavy Industries included the statement in the manuals in the interest of customer safety. If the in-dash lighter receptacle is ever used for a plug-in accessory such as a cel- lular phone, the portion of the recepta- cle’s internal mechanism (bi-metal) that causes a cigarette lighter plug to ‘pop out’ after its lighter element is heated may be damaged. Placing a lighter plug in a receptacle that has been damaged by a plug-in accessory may cause the plug to stick and overheat, which may in some cases cause a fire in the receptacle that can spread to surrounding areas. In the interest of customer satisfac- tion, Fuji Heavy Industries has agreed to change subsequent owner’s manuals to allow the use of the in-dash receptacle as an accessory plug, but only if it is not also used as a cigarette lighter. Note: The cigarette lighter receptacle can be used as a cigarette lighter or an acces- sory plug, but cannot be used as a ciga- rette lighter and an accessory plug. If the lighter socket is used even once for an accessory plug-in item, then it must never be used to operate the cigarette lighter element. The entire socket must be replaced with a genuine Subaru ciga- rette lighter element if the customer ever wants to use it as a cigarette lighter again." Here is the link to the release: http://www.northursalia.com/techdocs/pdf/electrical/socket.pdf Thanks to Oesi for the reference. Link to comment Share on other sites More sharing options...
DOHCEJ22E1 Posted March 17, 2013 Share Posted March 17, 2013 Or you can just do what I do & deal with the warped socket by pushing the lighter slightly to the side & hold it there to heat it up since it will never stick or get stuck. I don't smoke but one of my passengers get really antsy if she cannot smoke. Link to comment Share on other sites More sharing options...
