jkaszynski Posted March 15, 2013 Share Posted March 15, 2013 I keep seeing mention of 05-06 uppipes being catted and a possible bad day in the making. In the later models is there any benefit to upgrading them? Are they a restriction in any way (is the an actual benefit in efficiency) Link to comment Share on other sites More sharing options...
Brprs Posted March 15, 2013 Share Posted March 15, 2013 Yes, the break inside and and cause turbo failure and possibly more. You could get a used sti up pipe for $50 the doesn't have a cat inside. Link to comment Share on other sites More sharing options...
WaspGT Posted March 15, 2013 Share Posted March 15, 2013 Or you could get a real Up Pipe. I chose GrimmSpeed, because after further research they seemed the best bang for the buck as far as quality and affordability. Here's my thread... it's full of craziness as are all of mine, but nonetheless there is a ton of useful info, and pictures. Don't trust in cheap fixes... you'll only hurt your car;) http://legacygt.com/forums/showthread.php/new-grimmspeed-up-pipe-thoughtsi-202262.html Link to comment Share on other sites More sharing options...
Max Capacity Posted March 15, 2013 Share Posted March 15, 2013 You'll also need the 2.2k ohm resistor from radio shack to defeet the CEL for no egt probe. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
