lingling1337 Posted March 14, 2013 Share Posted March 14, 2013 This is the supply line kit I want right? Any good reason to go with the complete line kit? Or even the turbo installation kit (maybe see if they can cut me a deal to include a filtered line?) And is it recommended to get a new inlet hose? How about a heat shield (I already have a blanket). Thanks. Link to comment Share on other sites More sharing options...
Max Capacity Posted March 14, 2013 Share Posted March 14, 2013 I installed my vf52 using the stock oil feed lines with the banjo filter removed. Oh what turbo are you using ? You shouldreplace the oil return hose and I used bolts in place of the studs on the up pipe. I found it much easier to line the turbo inlet, oil return hose and up pipe all at the same time. I used the bolts that hold the up pipe bracket tot he block, the dealer has them. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
lingling1337 Posted March 14, 2013 Author Share Posted March 14, 2013 I'm using a rebuilt BNR 16g. EDIT: I think I'm gonna go with the ip&t filtered line without the avcs. And skip the inlet hose for sure. Max you don't happen to have the part number for those uppipe bolts do you? And where can I get a return hose, dealership? I couldnt find one on Infamous or FredBeans Link to comment Share on other sites More sharing options...
lingling1337 Posted March 14, 2013 Author Share Posted March 14, 2013 How's this look for an install kit? Uppipe to turbo gasket DP to turbo gasket 3" DP gasket Downpipe to catback adapter DP donut gasket Filtered turbo oil supply line kit Total: $248 Link to comment Share on other sites More sharing options...
Max Capacity Posted March 14, 2013 Share Posted March 14, 2013 That list looks good. The parts guy should be able to give you 5 each 10x1.25x 1" long or a little longer. Measure the flanges and get the bolt a little longer. They will have a $20.00 oil return hose too. Remember to use anti-seize compound and zip tie the vacuum hoses. If you can bring the up pipe with you and make sure the bolts fit. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
lingling1337 Posted March 14, 2013 Author Share Posted March 14, 2013 Ok cool. Any particular reason you recommend a new return line? Link to comment Share on other sites More sharing options...
Max Capacity Posted March 14, 2013 Share Posted March 14, 2013 When you see the old one you'll understand. It will be hard and ready to crack. Here's mine. notice the bolts. http://i185.photobucket.com/albums/x40/92Si/DSCN4783.jpg 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
lingling1337 Posted March 15, 2013 Author Share Posted March 15, 2013 Right on thanks for the pic Link to comment Share on other sites More sharing options...
