dark_thorns Posted March 11, 2013 Share Posted March 11, 2013 How can you tell which valve spring shim goes to which valve on an ej25d? I thought i had put them all back in order but just in case i didn't i wanna double check them, and i couldn't find any specifics in the service manual. Link to comment Share on other sites More sharing options...
JJay03 Posted March 12, 2013 Share Posted March 12, 2013 Only way to tell is to check the clearances. Link to comment Share on other sites More sharing options...
dark_thorns Posted March 12, 2013 Author Share Posted March 12, 2013 how exactly do you check the clearances? i've read where people just use a feeler gauge and measure the clearance from the cam lobe to the top of the shim. Link to comment Share on other sites More sharing options...
JJay03 Posted March 12, 2013 Share Posted March 12, 2013 Thats how you do it I dont have the specs in front of me right now though. You measure when the lobe on the cam is pointed away from the valve. Link to comment Share on other sites More sharing options...
dark_thorns Posted March 12, 2013 Author Share Posted March 12, 2013 so when the lobe is 180 from the shim? and what's an easy way to tell if your valves are properly seated? someone told me to put rubbing alcohol in the dome with the valves and spark plug and fill it, and if the alcohol doesn't leak out then they're sealed. does that seem right? i did this and the alcohol seemed to still be at the same level and i checked today but the alcohol all seeped through somewhere, but i also kept the alochol in there for a day straight, so i'm gonna guess that it's gonna leak through after that much time no matter what right? Link to comment Share on other sites More sharing options...
JJay03 Posted March 12, 2013 Share Posted March 12, 2013 I just made sure the lobe was 180 from the valve and measured. Then rotated the cam a time or 2 and checked again. Its kinda of tricky to measure the thickness of the current shims though to see what new sizes you need. I probably just needed a better gauge cause I ordered a bunch of shims and a lot of them were not correct. The book should explain the process. Link to comment Share on other sites More sharing options...
Osei Posted March 12, 2013 Share Posted March 12, 2013 See here: http://www.northursalia.com/techdocs/pdf/pdf.html look in engine section for how to do clearance. O. Link to comment Share on other sites More sharing options...
dark_thorns Posted March 13, 2013 Author Share Posted March 13, 2013 well sweet thanks you guys, i think i got what i needed. still unsure about the valve seating thing though. Link to comment Share on other sites More sharing options...
JJay03 Posted March 13, 2013 Share Posted March 13, 2013 well sweet thanks you guys, i think i got what i needed. still unsure about the valve seating thing though. Not quite sure what you mean why wouldnt the valve be seating unless there was a bunch of carbon or something in the way. Link to comment Share on other sites More sharing options...
dark_thorns Posted March 14, 2013 Author Share Posted March 14, 2013 well i'm just double checking through everything because i had rebuilt the engine but was in a huge hurry so i overlooked a lot of the small key things and ended up running off of 3 cylinders. so now that i've got it back apart i'm gonna make sure and do it right. i had little to no compression in cylinder 3 but i had swapped the B piston that was meant to be in cylinder 4 with an A piston from cylinder 2. Link to comment Share on other sites More sharing options...
