Mendozer Posted March 11, 2013 Share Posted March 11, 2013 I've been searching through the forum, and can't seem to find a detailed list of the difference CEL codes. I was hoping someone would be able to help me out. Again, I did try a search but was unable to find what I was looking for. This morning, I went to start my car, and the Check Engine Light came on. Also, the Cruise control light continues to flash. I let it sit for a few minds (while I checked all the fluids) and re-started. No issues, but lights still on. Car runs fine, went to work, let it sit for another 30mins (hoping it would re-set) and no dice. Lights still on. I did notice an ERR 55 (where the trip meter is). Again was hoping to find what this meant but was unable to. Anyone have a list of codes, or any guidance as to what it might be (before I bring it to the dealer)? Thanks, 2005 Legacy GT limited Wagon, manual ~136000km's Link to comment Share on other sites More sharing options...
Nrw Posted March 11, 2013 Share Posted March 11, 2013 There's a way to pull codes without a scanner. I forgot what's needed since I own my own scanner. I think Max Capacity knows the way to do it. Once the code(s) are read search them up and go from there. Link to comment Share on other sites More sharing options...
Mendozer Posted March 11, 2013 Author Share Posted March 11, 2013 There's a way to pull codes without a scanner. I forgot what's needed since I own my own scanner. I think Max Capacity knows the way to do it. Once the code(s) are read search them up and go from there. Sounds good...I'll try to swing by part source and get a reading. Thank you Link to comment Share on other sites More sharing options...
Max Capacity Posted March 11, 2013 Share Posted March 11, 2013 http://legacygt.com/forums/showthread.php/trouble-codes-cels-26113.html that was easy. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Max Capacity Posted March 11, 2013 Share Posted March 11, 2013 There's a way to pull codes without a scanner. I forgot what's needed since I own my own scanner. I think Max Capacity knows the way to do it. Once the code(s) are read search them up and go from there. Yea, I know how, but I have the direction on a piece of paper inth e glove box. I did print them from here, I think HAMMERDOWN or Frank_ster had the orginal thread with them. OP the CC light always flashes when you get a CEL, that's normal. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Mendozer Posted March 12, 2013 Author Share Posted March 12, 2013 http://legacygt.com/forums/showthread.php/trouble-codes-cels-26113.html that was easy. GAH, thank you...I suck at using the search function on this forum. I checked "CEL" and this mad awesome list sure didn't come up. THANK YOU... going to the dealers tomorrow, see how much they charge me to scan the car and give me the code. From there i'll either choose to invest in my own scanner or search around for an old method i used to use (use a paper clip to jump certain points). The number of blinks lead to what code it was...was this the method you speak of in your glove box? Link to comment Share on other sites More sharing options...
Motorman_55792 Posted March 12, 2013 Share Posted March 12, 2013 Just buy a scanner so you don't have to rely on the stealership. I bought on of Amazon for $16. Works perfectly. Link to comment Share on other sites More sharing options...
Nrw Posted March 12, 2013 Share Posted March 12, 2013 http://legacygt.com/forums/showthread.php/cel-code-reader-05-198606.html Found it I tend to search via google. Type in what you're looking for and legacygt.com Link to comment Share on other sites More sharing options...
Max Capacity Posted March 12, 2013 Share Posted March 12, 2013 http://legacygt.com/forums/showthread.php/cel-code-reader-05-198606.html Found it I tend to search via google. Type in what you're looking for and legacygt.com Gee who posted that...oh...never mind. OP Any auto parts store will read the code for free. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Mendozer Posted March 14, 2013 Author Share Posted March 14, 2013 $65 later, the dealer tells me its a LF wheel speed (ABS) sensor that's toast (code C0104). I wasn't able to find the code on the list, so I'm not sure exactly what that means. Anyways they want $200 for the repair, but the part is only $40.50 on SubaruGenuineParts. Anyone know how difficult it is to change? I looked at the manual and it looks rather simple!? unplug, replace, re-plug? Link to comment Share on other sites More sharing options...
Max Capacity Posted March 14, 2013 Share Posted March 14, 2013 Don't forget about pulling the wheel and brake off to get to the sensor, then remove two rusty bolts. Plus they will charge you more then 40.00 for the sensor. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
