JMLegacy Posted March 6, 2013 Share Posted March 6, 2013 Symptoms are: 1. Braking at high speed induces vibration 2. When brake is released, car is still vibrating for a minute or so Idk if the rotors cause this as I recently skimmed n got new pads, and the fact that it still vibrates after I stopped holding the brake, Idk, Also I only see the problem of I'm doing over 110 or so Any ideas? Link to comment Share on other sites More sharing options...
orndog Posted March 6, 2013 Share Posted March 6, 2013 That is scary, warped rotors wouldn't vibrate the car after releasing the brakes. Link to comment Share on other sites More sharing options...
JMLegacy Posted March 6, 2013 Author Share Posted March 6, 2013 Hope some suspension geek will chime in soon. Need this fix with as little trial and error as possiblr Link to comment Share on other sites More sharing options...
whitetiger Posted March 6, 2013 Share Posted March 6, 2013 It's the rotors. The pad are still making contact with the roots even if you aren't on the brakes. The shake takes a moment to spread the pads far enough apart so that it stops. Link to comment Share on other sites More sharing options...
austin42008 Posted March 6, 2013 Share Posted March 6, 2013 ^ What he said Link to comment Share on other sites More sharing options...
JMLegacy Posted March 7, 2013 Author Share Posted March 7, 2013 What do I do? Are they warped or too thin, or what? Do the rear rotors give this problem? Link to comment Share on other sites More sharing options...
captainobvious Posted March 7, 2013 Share Posted March 7, 2013 How do your lower control arm bushing look? Link to comment Share on other sites More sharing options...
I Donated Too laff79 Posted March 7, 2013 I Donated Too Share Posted March 7, 2013 buy new rotors/pads for the front. If still persists, do the back too Link to comment Share on other sites More sharing options...
orndog Posted March 7, 2013 Share Posted March 7, 2013 It's the rotors. The pad are still making contact with the roots even if you aren't on the brakes. The shake takes a moment to spread the pads far enough apart so that it stops. Excellent point, I didn't consider that. Also, once you do the work properly bed them. Link to comment Share on other sites More sharing options...
