icelatte Posted August 4, 2005 Share Posted August 4, 2005 I was going to get the 18x8 gt2 from tirerack but the 18x8.5 are actually $40 less expensive in silver. the offset for 18x8.5 is +48 so they should fit. I'm going to run 225/40/18 either way so my question - is there any advantage in running 8.5 and save $40 a wheel or should I save 1.2 pounds per wheel and go with 8 in. Thanks Link to comment Share on other sites More sharing options...
MUD Posted August 4, 2005 Share Posted August 4, 2005 Go wider on the tire if you're running 8.5" tires. Are you talking about Integral GT2? Cause I couldn't find those on Tire-rack. Were you using a different vehicle? It is the disposition of men to desire that which he cannot have, hence my un-quenchable wet desire for Shakira! Link to comment Share on other sites More sharing options...
nendo Posted August 4, 2005 Share Posted August 4, 2005 id go 8' wide rims.. if u r going huge power then go 8.5 to put even wider tires on.. those ssr gt2 r an awsome wheel,, make sure u post pics when u get em Link to comment Share on other sites More sharing options...
Xenonk Posted August 4, 2005 Share Posted August 4, 2005 you get a stiffer sidewall with the 8.5" and better footprint as well. The 8" saving some weight is really nothing like compared to going to a 17" rim anyways. for a 8" rim, you shoudl run a minimum of a 225/40/18, but if you are going with the 8.5", you better put on a 255/35/18 on them. Keefe Keefe Link to comment Share on other sites More sharing options...
icelatte Posted August 4, 2005 Author Share Posted August 4, 2005 Thanks guys, I'll mull it over. I guess it will depend on how much tire I decide to run. Mud, you have to use the wrx or sti to search for the gt2. Link to comment Share on other sites More sharing options...
PGT Posted August 4, 2005 Share Posted August 4, 2005 225/40 is noticably taller than stock. I just went to a 245/35 on an 8" wheel - from what Keefe told me, that's the limit on tire width that a stock suspension can take advantage of. From the wear on the outside edge of my tires....I am using all of it, but I have to really push the car to levels not fit for the street to get into the mechanical traction the tires provide (vs. the suspension alone). Link to comment Share on other sites More sharing options...
icelatte Posted August 5, 2005 Author Share Posted August 5, 2005 This may come down to tire availability. I was going to buy the Kumho mx from tirerack as well, but they only have 225/40, no 245/35 or 255/35. Goodyear f1 and kdw 2 come in that size but I was planning on using these for track and autocross. So stickier tire or wider tire? Maybe I should just stick with a 17 wheel and get the mx in 245/40. Thanks a lot for your help guys. My wife thinks I'm spending too much time thinking about this. I think I agree and just want to start putting the rubber down. Link to comment Share on other sites More sharing options...
eVoMotion Posted August 5, 2005 Share Posted August 5, 2005 My T1-Rs just arrived today - 245x35/18. I am very curious to see how well they run on and off the track. Attached is a tire spec, width, rotation guide. Bought from: http://www.liteswap.com/merchant2/merchant.mvc?Screen=PROD&Product_Code=toyoT1R&Category_Code=toyosummerToyoT1R.pdfToyoT1R.pdf Link to comment Share on other sites More sharing options...
icelatte Posted August 11, 2005 Author Share Posted August 11, 2005 18x8 GT2 in silver with 225/40/18 Kumho mx on the way. Thanks to Luke at tirerack for the help. Lucky bastard's going to europe for a WRC rally, then a couple laps of the 'ring. Link to comment Share on other sites More sharing options...
zildjiank Posted August 12, 2005 Share Posted August 12, 2005 you get a stiffer sidewall with the 8.5" and better footprint as well. The 8" saving some weight is really nothing like compared to going to a 17" rim anyways. for a 8" rim, you shoudl run a minimum of a 225/40/18, but if you are going with the 8.5", you better put on a 255/35/18 on them. Keefe Hey keefe....you mean to tell me that this wheel comes in 18X8.5 w/ a 48mm offset? how sweet! The chart says that the 18X8.5 w/ a 255 tire will be 26lbs....you drive an 18X8 w/ a 255...how does that affect the driving? and acceleration? Is it significantly slower? Would it be like driving stock when you have the AP installed? I mean is it that bad of lag on the car as far as weight goes....? Link to comment Share on other sites More sharing options...
icelatte Posted August 13, 2005 Author Share Posted August 13, 2005 Someone emailed me with a question regarding the GT2 but I deleted it inadvertantly. If you see this, try again. Link to comment Share on other sites More sharing options...
Xenonk Posted August 13, 2005 Share Posted August 13, 2005 Hey keefe....you mean to tell me that this wheel comes in 18X8.5 w/ a 48mm offset? how sweet! The chart says that the 18X8.5 w/ a 255 tire will be 26lbs....you drive an 18X8 w/ a 255...how does that affect the driving? and acceleration? Is it significantly slower? Would it be like driving stock when you have the AP installed? I mean is it that bad of lag on the car as far as weight goes....? yes, the wheel comes in 18x8.5 +48mm offset... as far as your tire weight concerns, that is a ?? to me. My current 18x8 with 255/35/18 feels very much so like my 17"x7.5" with 225/45/17 Falken Azenis (stiff sidewalls).. the only difference is that the Toyo T1-S is not as grippy as the Falkens Azenis. The 17x7.5 really does feel a lot lighter than stock, but the 18x8 feels very close to stock characteristics. I would say that even my 18x8 SSRs GT7s still feel like a stock 17x7 with the Potenza RE92s, but at least I have more grip and better rain traction than stock due to tire compounds differences. Keefe Keefe Link to comment Share on other sites More sharing options...
