Indiglow Posted March 5, 2013 Share Posted March 5, 2013 let's put it this way. the red should connect to the black each other in order to activate test mode. no homo. Link to comment Share on other sites More sharing options...
psapitch13 Posted March 5, 2013 Author Share Posted March 5, 2013 Right. I haven't been able to get into test mode yet...hopefully the next time I update I will be stage 2. Just in time to play in the snow tomorrow. Link to comment Share on other sites More sharing options...
Max Capacity Posted March 5, 2013 Share Posted March 5, 2013 Trying to upload a photo of mine to the site. Get rid of those yellow wires, splice that pink wire back together and you should be back to stock. Here are mine. http://i185.photobucket.com/albums/x40/92Si/DSCN5151_zpsca9db2a6.jpg 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
psapitch13 Posted March 6, 2013 Author Share Posted March 6, 2013 Thanks for the help! I disconnected the yellow wires and hooked up the red ones and I was able to flash the ecu into stage 2 93 V118. Looking forward to getting the right setup for my mods. Link to comment Share on other sites More sharing options...
SilvrFyre Posted March 6, 2013 Share Posted March 6, 2013 Did you manage to trace where those yellow wires went off to? I didn't see them in the pic of the fuse panel with the added button. Flipapotimus was right. They should go to a switch that the previous owner added (just not the one you took a pic of) to get in and out of test mode quickly. They must have been using trial and error engine mapping...yay. Link to comment Share on other sites More sharing options...
psapitch13 Posted March 6, 2013 Author Share Posted March 6, 2013 I looked around to try to find where the yellow wires went to, but I can't figure it out. it seems like they go across the car to the drivers side but I couldn't see where without tearing the dash apart. Link to comment Share on other sites More sharing options...
Max Capacity Posted March 6, 2013 Share Posted March 6, 2013 Did you manage to trace where those yellow wires went off to? I didn't see them in the pic of the fuse panel with the added button. Flipapotimus was right. They should go to a switch that the previous owner added (just not the one you took a pic of) to get in and out of test mode quickly. They must have been using trial and error engine mapping...yay. From what I remember from the photo's, didn't both yellow wires come from the pink wire ? To have a switch to change maps, one of the yellow wires would have to come from the blue wire. Right ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
psapitch13 Posted March 7, 2013 Author Share Posted March 7, 2013 I am not sure, I will take a look at it. Going on vacation for a little while...so it will need to wait. Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted March 7, 2013 I Donated Share Posted March 7, 2013 The PO probably just kept it plugged in and toggled the switch as needed. Link to comment Share on other sites More sharing options...
mwiener2 Posted March 13, 2013 Share Posted March 13, 2013 You guys wiring skillz teh suks My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
psapitch13 Posted March 13, 2013 Author Share Posted March 13, 2013 I haven't been able to find a switch anywhere, but now I am getting a code thrown for P0245 turbo wastegate solenoid A low. I can't seem to clear it with the accessport. Any suggestions would be awesome, I searched but there doesn't seem to be much available for help. Link to comment Share on other sites More sharing options...
Max Capacity Posted March 13, 2013 Share Posted March 13, 2013 You may want to make sure you don't have a cracked vacumm hose in the circuit for boost control. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
psapitch13 Posted March 13, 2013 Author Share Posted March 13, 2013 I do have an external wastegate, will that have thrown it? Link to comment Share on other sites More sharing options...
Max Capacity Posted March 13, 2013 Share Posted March 13, 2013 I'm guessing yes, contact a tuner, I use http://www.tuningalliance.com contact Mike through his web page or from his link inthe Vendor Forum here. You can tell him I sent you. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
psapitch13 Posted March 13, 2013 Author Share Posted March 13, 2013 Sent them an email, thanks! Link to comment Share on other sites More sharing options...
Max Capacity Posted March 13, 2013 Share Posted March 13, 2013 Your welcome, if he can help you out, remember him next time you want to upgrade your car. He can get most anything like most of the other guy's on here. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted March 14, 2013 I Donated Share Posted March 14, 2013 I do have an external wastegate, will that have thrown it? You have an EWG with stock turbo? Link to comment Share on other sites More sharing options...
psapitch13 Posted March 14, 2013 Author Share Posted March 14, 2013 You have an EWG with stock turbo? I am learning that apparently that is strange, I bought it like that...Will that do damage to my car until I want to put a bigger turbo on? I talked with Mike at tuningalliance and he is going to do an e tune for me. So hopefully we can get this thing running proper. Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted March 14, 2013 I Donated Share Posted March 14, 2013 I am learning that apparently that is strange, I bought it like that...Will that do damage to my car until I want to put a bigger turbo on? Not if you are tuned properly for it. You sure you have an EWG? Some people get confused because the actuator arm is external, but the WG is really inside the turbine housing. Link to comment Share on other sites More sharing options...
psapitch13 Posted March 14, 2013 Author Share Posted March 14, 2013 I am 99.9% it is external (hopefully the noise isn't something else). The person who sold me the car said it was, which I thought was a good thing, here is the pic of it. http://i1102.photobucket.com/albums/g453/qsmgto13/2005%20Legacy%20GT/1b91847e-67ba-4db8-895e-5dc112523ece_zps472e2017.jpg Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted March 14, 2013 I Donated Share Posted March 14, 2013 That looks like an EWG, all right. Puzzling why anyone would do that on a stock turbo, though... Link to comment Share on other sites More sharing options...
psapitch13 Posted March 15, 2013 Author Share Posted March 15, 2013 I think the previous owner had plans to turn this car into a monster, but ran out of money. Link to comment Share on other sites More sharing options...
