DoDo1975 Posted February 28, 2013 Share Posted February 28, 2013 I have seen several posts where it is recommended to clean the throttle body, but can't find a good description on how this is done. There has been reference to removing the intake manifold and wiping it out, and another saying to just remove the throttle body. What is the best way to do this? It appears as though removing the throttle body is fairly simple, whereas the IM takes much more effort. What would you do to the Throttle body once it was off? Any tips are appreciated. Link to comment Share on other sites More sharing options...
Max Capacity Posted February 28, 2013 Share Posted February 28, 2013 First question is why ? When I had my engine apart for the new short block. I removed the tgv's, intake and TB as a unit and left it alone. I did tighten the fuel line clamps but other than that I did not touch the TB. I even left all the electrical connectors attached that didn't need to come off. If it ain't broke don't fix it. If you want to wipe the opening with a clean towel, go ahead. But I wouldn't be playing with it. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
DoDo1975 Posted May 17, 2013 Author Share Posted May 17, 2013 There are numerous posts claiming that a dirty throttle body might be a cause of rough idling? After trying everything else, where do you turn? Link to comment Share on other sites More sharing options...
tmagi Posted May 19, 2013 Share Posted May 19, 2013 To your local subaru mechanic? Not trying to be a wise guy, but sometimes there's a reason we pay them so much. What all did you try? Link to comment Share on other sites More sharing options...
DoDo1975 Posted May 19, 2013 Author Share Posted May 19, 2013 Hahahahahaha. You must be kidding. Its been in to 3 mechanics, including the Stealership. Oh no code, no problem. They are more than willing to charge me $110 an hour plus parts to randomly change things but after just spending $10k on this POS its not going back to Subaru unless there is something easily diagnosable. I am not paying $110 per hour for somebody to fumble around trying the same things I can try at home. Link to comment Share on other sites More sharing options...
Mr. Sinister Posted May 20, 2013 Share Posted May 20, 2013 Did you clean your MAF sensor yet? I'd try that before trying to clean the throttle body. While you're at it, what else have you tried? There are lots of causes of a rough idle from vacuum leaks to cracked pistons. My rough idle turned out to be caused by bad valve clearances. Link to comment Share on other sites More sharing options...
