mungewell Posted February 27, 2013 Share Posted February 27, 2013 Hi, Not a legacy but the Forester is near identical.... my drive shaft failed on the way out the office parking lot. Pulled a bit of a slide in the snow and that seems to have been too much for it (in it's already failing state). This is also failed last year so I suspect that there's something else wrong. I did notice the car 'crabbling' a little bit during a tight turn in a parking lot a whiles ago - so perhaps the LSD/Differential inside the gear box has failed. The car is a 2001 Forester S Sport. Anyhow, I left it at work and walked to my friends house - which I can do till the end of the week. But then I have 200km journey home.... :-( Dropping the drive shaft out is not a problem (done this before, just a few bolts), but the question is whether I can drive the car OK without it ??? - ie. just in front wheel drive. Again this is the drive shaft from rear of gearbox to the back differential. Thanks for any help/advise. Simon. Link to comment Share on other sites More sharing options...
Max Capacity Posted February 27, 2013 Share Posted February 27, 2013 How will you keep the fluid from coming out the back of the tranny ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
mungewell Posted February 27, 2013 Author Share Posted February 27, 2013 How will you keep the fluid from coming out the back of the tranny ? Driveshaft is a 'dry fit', just presses lightly into place. I'll see if there's any seals/leaks. Simon. Link to comment Share on other sites More sharing options...
Max Capacity Posted February 27, 2013 Share Posted February 27, 2013 May be your right, I did look when I had mine out. I guess you can stand the tranny up on end and not fluid will come out the tail shaft ? Not sure the ECU will be happy...Really though, I have no idea if you can drive the car from just the front wheels and not have any CEL's or other issues. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
mungewell Posted February 27, 2013 Author Share Posted February 27, 2013 ...and not have any CEL's This is a 2001 Forester with 350,000km on the clock. CEL's are the least of my worries ;-) I'm more worried about the amount of 'credits' getting my wife to drive a 400km round trip to "come and get me" is going to cost... Going to pull the driveshaft after work (in the parking lot) and take it for a little test drive. Link to comment Share on other sites More sharing options...
mungewell Posted February 28, 2013 Author Share Posted February 28, 2013 Well it's out, lets see if I get home on Friday.... http://farm9.staticflickr.com/8381/8513692329_28beb54321_m.jpghttp://farm9.staticflickr.com/8530/8513692467_07ae639844_m.jpg Next is to figure out why the car is busting these, this is the second one to fail like this. Simon. Link to comment Share on other sites More sharing options...
Max Capacity Posted February 28, 2013 Share Posted February 28, 2013 At least try and cover the hole to keep crap out of it. Good Luck. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
