the pizza Posted February 23, 2013 Share Posted February 23, 2013 My 2005 leggy broke down, and the code reader said iy was 0335 or crankshaft sensor malfunction. My friend said if I can reach it , Then I could wiggle it and make sure its seated on there, and maybe it will fire up . Anybody else ever have problems with their crankshaft sensor? Link to comment Share on other sites More sharing options...
Max Capacity Posted February 23, 2013 Share Posted February 23, 2013 It's on the center of the front of the engine above the crank pulley and below the alternator. You may be able to get to it with out to much trouble. I'll send you a link 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
