yellowxowner Posted February 4, 2013 Share Posted February 4, 2013 So I Picked up a 2.5i SE a month ago, this thing is a POS. 2nd day owning it and get a CEL P2097. Get it checked and yes the O2 sensor is bad. Get that fixed now getting P0457 Major Evap leak, they replaced the gas cap and guess what it came back a few days later. Took it in today to have it smoke tested, they find nothing. They are going to check with their master techs to see if they have any other ideas to try to fix it. Anyone have any ideas to suggest they try? I am only starting to get to understand these cars, I could put a suspension lift on an Xterra in my sleep, but am clueless with this car so far. My wifes 06 2.5i has been flawless, this one sucks. HELP! Link to comment Share on other sites More sharing options...
Max Capacity Posted February 4, 2013 Share Posted February 4, 2013 The evap can is on the firewall. May be a hose is cracked ? Just watched a youtube video on P0457, the Evap canister is behind the drivers side rear tire, behind the plastic inner fender liner. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
yellowxowner Posted February 5, 2013 Author Share Posted February 5, 2013 Would they have found that during the smoke test? Link to comment Share on other sites More sharing options...
yellowxowner Posted February 6, 2013 Author Share Posted February 6, 2013 Well they looked around more and still not sure what is wrong. Tonorrow they are going to check some wiring and then selinoids to see if that is the problem. Link to comment Share on other sites More sharing options...
ehsnils Posted February 6, 2013 Share Posted February 6, 2013 Looks a bit like someone sold you a lemon. Link to comment Share on other sites More sharing options...
yellowxowner Posted February 8, 2013 Author Share Posted February 8, 2013 Well they supposedly found some loose connections on the ecu that they fixed. Lets see if that fixes it. Link to comment Share on other sites More sharing options...
yellowxowner Posted February 20, 2013 Author Share Posted February 20, 2013 Been 2 weeks without issue....but now I had the neighbors dog scratch the door by jumping on it. I have horrible luck with this car. Link to comment Share on other sites More sharing options...
spoondek Posted June 25, 2013 Share Posted June 25, 2013 I have the same problem. Did the code come back up? Link to comment Share on other sites More sharing options...
chato Posted June 25, 2013 Share Posted June 25, 2013 what is the dog door scratch code? Link to comment Share on other sites More sharing options...
Max Capacity Posted June 25, 2013 Share Posted June 25, 2013 I have the same problem. Did the code come back up? what is the dog door scratch code? Good one, that's funny. spoondek, check the harness at the ECU. check here you might find some useful help. http://people.csail.mit.edu/ilh/vacation/ 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
