derp Posted December 20, 2017 Share Posted December 20, 2017 If I'm going to the trouble of a non-native swap, it's not going to be a 4 banger... Fair enough, if I'm going to go through the trouble of having a daily and a fun car I'm sure not choosing a miata. I could suck start a snow blower. Link to comment Share on other sites More sharing options...
rodan Posted December 21, 2017 Share Posted December 21, 2017 Has anyone swapped in the newer 2.4DIT(?) From the CX9? Not that I'm aware of... I have heard of a couple of MZR 2.0s swapped in, but it's a lot of work for little benefit. Some of the new direct injection engines create packaging issues with the HPFP on the back of the head in a longitudinal orientation, and the tuning solutions are almost non-existent. Link to comment Share on other sites More sharing options...
Chris GTO TT Posted December 21, 2017 Author Share Posted December 21, 2017 The other issue with newer engine swaps is lots of times they are so dependent on the CAN Bus they simply won’t work right without it. One of the reasons the LS swaps works so well is because, even for the modern versions, GM sells it as a complete standalone engine and control package. 2003 Baja 5MT 2016 Outback 2.5i Premium w/Eyesight Link to comment Share on other sites More sharing options...
rodan Posted December 22, 2017 Share Posted December 22, 2017 Swapped wheels on the NBs. Konigs look good on the black car... BlackNB Konig by Rodan AZ, on Flickr Also discovered the previous owner filled the coolant with straight water... found a puddle underneath, and the lower radiator hose was pushed off the radiator by a nice popsicle! I extracted the popsicle, and got the hose back in place. I ran the engine up to temp, but still wasn't getting warm air from the heater. I'm letting it sit for a while, so the engine heat can thaw things out... I didn't find any other damage, so I'm hoping I don't have a bigger problem. Link to comment Share on other sites More sharing options...
Chris GTO TT Posted December 22, 2017 Author Share Posted December 22, 2017 Yikes! Got lucky if the only issue was the one pipe pushed off slightly! I run about 70% water here since our lowest lows are usually I'm the upper 20s. 2003 Baja 5MT 2016 Outback 2.5i Premium w/Eyesight Link to comment Share on other sites More sharing options...
rodan Posted December 22, 2017 Share Posted December 22, 2017 Well... radiator is toast. Looked like a sprinkler once I got it thawed.... Hopefully, that's the worst of it. I couldn't find any other spots leaking. New radiator on the way from Amazon. It's pretty common to get into the 20s here, and not uncommon to see teens this time of year. Last night was the coldest night so far this year... forecast was 12*... Link to comment Share on other sites More sharing options...
Chris GTO TT Posted December 23, 2017 Author Share Posted December 23, 2017 Ouch good new is stock style radiators are pretty cheap for the Miata. It's much better to lose the radiator than a freeze plug in the block. 2003 Baja 5MT 2016 Outback 2.5i Premium w/Eyesight Link to comment Share on other sites More sharing options...
ehsnils Posted December 23, 2017 Share Posted December 23, 2017 Even worse - lose the block. Link to comment Share on other sites More sharing options...
rodan Posted December 25, 2017 Share Posted December 25, 2017 So, new radiator arrived yesterday(!). I installed it, and have no leaks, and no nasty noises, and no water in the oil, but water is not circulating through the cooling system. Next step is T-stat... I don't know if freezing can kill one and cause it to fail closed, but that appears the likely scenario. The other possibility is the water pump, but if it was damaged, I would expect leaks or nasty noises, and I have neither... If the T-stat doesn't fix it, I'll just yank the motor and check it out after I swap in the manual drivetrain. And MERRY CHRISTMAS!! to the LGT Miata community! Link to comment Share on other sites More sharing options...
Chris GTO TT Posted December 25, 2017 Author Share Posted December 25, 2017 Merry Christmas to you too! I'm just hoping to get the car to the house soon. 2003 Baja 5MT 2016 Outback 2.5i Premium w/Eyesight Link to comment Share on other sites More sharing options...
rodan Posted December 28, 2017 Share Posted December 28, 2017 (edited) 949FdEx by Rodan AZ, on Flickr Edited December 28, 2017 by rodan Link to comment Share on other sites More sharing options...
Chris GTO TT Posted December 28, 2017 Author Share Posted December 28, 2017 What did you order from Emilio now? 2003 Baja 5MT 2016 Outback 2.5i Premium w/Eyesight Link to comment Share on other sites More sharing options...
rodan Posted December 28, 2017 Share Posted December 28, 2017 You'll have to wait for the unboxing Link to comment Share on other sites More sharing options...
ehsnils Posted December 28, 2017 Share Posted December 28, 2017 You'll have to wait for the unboxing Russian Christmas celebration for you? Link to comment Share on other sites More sharing options...
rodan Posted December 28, 2017 Share Posted December 28, 2017 For the NA, anyway... Link to comment Share on other sites More sharing options...
Chris GTO TT Posted December 28, 2017 Author Share Posted December 28, 2017 Front brakes? 2003 Baja 5MT 2016 Outback 2.5i Premium w/Eyesight Link to comment Share on other sites More sharing options...
rodan Posted December 28, 2017 Share Posted December 28, 2017 . Link to comment Share on other sites More sharing options...
BDII Posted December 28, 2017 Share Posted December 28, 2017 Ls1? Need forum help? Private Message legGTLT Link to comment Share on other sites More sharing options...
rodan Posted December 28, 2017 Share Posted December 28, 2017 949 doesn't sell LS conversion stuff. Chris got it in one guess... Link to comment Share on other sites More sharing options...
Chris GTO TT Posted December 28, 2017 Author Share Posted December 28, 2017 As soon as you said it was for the NA I knew what it was, but I am interested in what kit you went with. 2003 Baja 5MT 2016 Outback 2.5i Premium w/Eyesight Link to comment Share on other sites More sharing options...
rodan Posted December 28, 2017 Share Posted December 28, 2017 As soon as you said it was for the NA I knew what it was, but I am interested in what kit you went with. For that, you'll have to wait 'till tomorrow... Funny thing, I ordered the rear rotors from Amazon the other day. They're just Centric stock NB sport rears. Weird thing is they both showed up today... one from UPS and the other USPS... gotta love Amazon! On the NB front, I started on the big drivetrain swap today. Big swap start by Rodan AZ, on Flickr It's a lot of work prepping to pull the engine/trans on two cars! Link to comment Share on other sites More sharing options...
fredrik94087 Posted December 28, 2017 Share Posted December 28, 2017 And, your wife is ok with this? I tried showing my wife your driveway with 3 miatas to plant the seed of a third car (for me), but my dreams were squelched before you could say "hobby car". Major kudos and brass you know what for pulling that off on the entire width of your driveway. "It's within spec" - SOA "Depth is only shallowness viewed from the side." - Fredism "So, how much did it cost for your car to be undriveable ." - Stephen (very close friend) "You have done so much it would be stupid to go back." - Sunny of Guru Electronics 2018Q50RS | 2015WrxThread | Shrek Link to comment Share on other sites More sharing options...
rodan Posted December 29, 2017 Share Posted December 29, 2017 I got lucky with the weather... if she has to scrape windows in the mornings I hear about it... Hoping to have this done in a couple of days anyway. Link to comment Share on other sites More sharing options...
ehsnils Posted December 29, 2017 Share Posted December 29, 2017 I got lucky with the weather... if she has to scrape windows in the mornings I hear about it... Hoping to have this done in a couple of days anyway. Here it's more surprising not having to scrape the windows and it often means it's raining instead this season. Link to comment Share on other sites More sharing options...
rodan Posted December 29, 2017 Share Posted December 29, 2017 Our forecast is 73F and sunny today... definitely not normal for this time of year. Typically the daytime high would be in the high 40s/ low 50s. I'm doing my best to take advantage of it! Overnight low is still 23F, though... so I'm not getting started 'till it warms up! Link to comment Share on other sites More sharing options...
