I Donated thefultonhow Posted January 28, 2013 I Donated Share Posted January 28, 2013 It doesn't have to make sense. I presented the information that is available from Subaru. If you only disagree because it doesn't make sense to you, then I do not know what to tell you. Not everything makes sense, it's part of life. Get used to it. Apparently, you are incapable of comprehending the difference between "that doesn't make sense" and "there's no way that could be true." Hint: I said the first one, not the second one. Link to comment Share on other sites More sharing options...
awwrxwgn Posted January 29, 2013 Author Share Posted January 29, 2013 dropping the car off on Wednesday night, hopefully it will be fixed by Thursday afternoon. I guess it's nice to find a dealer with a service manager that is informative and easy to work with. Link to comment Share on other sites More sharing options...
wpmarky Posted January 29, 2013 Share Posted January 29, 2013 Fulton, you're the one that doesn't make any sense now. +1 to what BJW said. If you only disagree because it doesn't make sense, then gg. Making sense doesn't matter in dealing with warranty work, only what is on paper. HINT: BJW was referring to the first one, not the second one. Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted January 30, 2013 I Donated Share Posted January 30, 2013 Fulton, you're the one that doesn't make any sense now. +1 to what BJW said. If you only disagree because it doesn't make sense, then gg. Making sense doesn't matter in dealing with warranty work, only what is on paper. HINT: BJW was referring to the first one, not the second one. I'm not disagreeing with you or BJW that the turbo is not covered under the new-car powertrain warranty. That fact is abundantly clear. I'm simply saying it doesn't make any sense to not be covered when it is covered under the CPO one, and I'm wondering what justification Subaru has for that difference. I don't see what's so hard to understand about that. dropping the car off on Wednesday night, hopefully it will be fixed by Thursday afternoon. I guess it's nice to find a dealer with a service manager that is informative and easy to work with. So what did they say the problem was? And is it covered under warranty? Link to comment Share on other sites More sharing options...
seanbru Posted January 31, 2013 Share Posted January 31, 2013 Not positive, but I believe your issue could be a wheel sensor. Not an expensive fix. Water or a hard bump can mess them up. You can replace it yourself but you gotta know what wheel sensor it is. Again, not positive, but that is how a car acts with a faukty wheel sensor. Link to comment Share on other sites More sharing options...
awwrxwgn Posted January 31, 2013 Author Share Posted January 31, 2013 they are replacing the gaskets under warranty, so hopefully it should be good to go. Link to comment Share on other sites More sharing options...
awwrxwgn Posted February 1, 2013 Author Share Posted February 1, 2013 all I an say is wow, car runs so much better now. 4 degrees this morning and no hesitation at all, can barely tell the car is running. This is why I continue to buy Subarus... Link to comment Share on other sites More sharing options...
