Baddog Posted January 22, 2013 Share Posted January 22, 2013 So my power door locks haven't worked since my car was stolen and the radio was taken out. Is there any wiring or switch or something of that nature behind the radio that controls the power locks? Mine is a 96 which has the setup where the driver door controls the other 3 doors. I am curious as to what look for. Electrical is not my forte per say. Heh. Link to comment Share on other sites More sharing options...
SpecBamf41 Posted January 22, 2013 Share Posted January 22, 2013 the guy that stole it may have unplugged the box that controls all that in attempt to get rid of the flashing hazards. BNR18g on 93oct Link to comment Share on other sites More sharing options...
Baddog Posted January 22, 2013 Author Share Posted January 22, 2013 Car doesn't have that alarm setup on it. So when the alarm goes off it doesnt set off the hazards. There is no alarm at all on the car. What box? Link to comment Share on other sites More sharing options...
SpecBamf41 Posted January 22, 2013 Share Posted January 22, 2013 Its not part of the alarm. Its part of the remote acsess module. Aka keyless entry. It has to be pluged in to power any lock with the remote. Also. Check the two grounds that are located on the left ans right dash mount points below the radio. Maybe he unplugged them. Sent from my SCH-I800 using Tapatalk 2 BNR18g on 93oct Link to comment Share on other sites More sharing options...
Baddog Posted January 22, 2013 Author Share Posted January 22, 2013 Heh. Im lost. I dont have keyless entry......... Link to comment Share on other sites More sharing options...
SpecBamf41 Posted January 22, 2013 Share Posted January 22, 2013 Dude. maybe your switch just wore out. Sent from my SCH-I800 using Tapatalk 2 BNR18g on 93oct Link to comment Share on other sites More sharing options...
subieadam Posted January 22, 2013 Share Posted January 22, 2013 What are power door locks??? Oh the luxuries lol Link to comment Share on other sites More sharing options...
Baddog Posted January 22, 2013 Author Share Posted January 22, 2013 Dude. maybe your switch just wore out. Sent from my SCH-I800 using Tapatalk 2 Could be a coincidence that it happened. Who knows. Happened right after it was stolen. Link to comment Share on other sites More sharing options...
Sylvester Posted March 26, 2014 Share Posted March 26, 2014 Similar issue. My locks don't work. There is a security light on my dash; does this mean I have an alarm?!?!? An alarm that's deactivated?!? I don't have keyless entry. Mines a 95 legacy wagon. How do I fix my locks?!? Link to comment Share on other sites More sharing options...
06lgtspecb Posted March 26, 2014 Share Posted March 26, 2014 Have you checked something as simple as the fuses? Link to comment Share on other sites More sharing options...
Baddog Posted March 26, 2014 Author Share Posted March 26, 2014 Wow. This is back from the dead. When I had my new stereo installed there was a cut wire back there I guess. They fixed all the wiring and the power door locks worked. Link to comment Share on other sites More sharing options...
Sylvester Posted March 26, 2014 Share Posted March 26, 2014 Just bought the car, haven't had a chance to do anything. I'll check the fuse when I get home. Hope it's so something so simple as that If it's not, does anyone have info on the actuators on the door? What to look for? A thread to follow? All the threads about locks are dealing with hatch locks that don't open; mine doesn't lock :/ Link to comment Share on other sites More sharing options...
Zues Marine Posted March 27, 2014 Share Posted March 27, 2014 Wow. This is back from the dead. I commend him for actually using the search, haha Link to comment Share on other sites More sharing options...
Sylvester Posted March 28, 2014 Share Posted March 28, 2014 The fuse is not the problem So, now how about those actuators? Link to comment Share on other sites More sharing options...
twisty Posted March 28, 2014 Share Posted March 28, 2014 actuators are just solenoids, and the 95-96 have 4 of them. 1 each in all the doors but the driver door, and one in the hatch. they are all triggered by the lock mechanism in the driver door. for later models (which im assuming you have, since there is a security light) have all 4 doors actuated. it should be a small unit inside the door skin, probably along the back side where the latch is located. there will be a 12v wire and ground to it, as well as a rod (or 2) that links it to the lock mechanism for the door. it is easy enough to disconnect the harness (you have to reach inside the door to do this) and plug a 9v battery with wires attached to it and activate the solenoid, proving the thing works. if they work at the actuator, you can start looking for the keyless entry module under the kick panel and see why it isnt working anymore. not sure what else you need an answer for, there are only 3 parts to the system. controller (under kick panel), relays (probably under the dash), and the actuators. if the actuators work, reprogram your fob and see if it starts working. if not, start looking at the control module. Link to comment Share on other sites More sharing options...
Sylvester Posted March 28, 2014 Share Posted March 28, 2014 I don't have a key fob, just a key. I'm just trying to lock/unlock all doors and hatch with the drivers door, the way it's supposed to. Link to comment Share on other sites More sharing options...
twisty Posted March 28, 2014 Share Posted March 28, 2014 security light on dash = built in security system no fob means you should try to find one. regardless of all that, the door locks arent being activated, so... trace the signal like i mentioned above. test the actuators. if they work, test the buttons. if they work, find the relays. if you have a 97+ find the keyless entry controller and figure out why it isnt triggering. Link to comment Share on other sites More sharing options...
Sylvester Posted March 29, 2014 Share Posted March 29, 2014 It's a 95 ls. Does that make a difference? Link to comment Share on other sites More sharing options...
johnegg Posted March 29, 2014 Share Posted March 29, 2014 if the solenoid has no power going to it, check the wiring where it jumps from the A pillar to the door. breaks there are not common, but it is a place where they could happen. but look for power, and ground in the door first. Link to comment Share on other sites More sharing options...
