Gmoe Posted January 24, 2013 Share Posted January 24, 2013 just when i thought you have done the craziest/coolest thing that's possible to do, you go and start looking into this.. nice. Link to comment Share on other sites More sharing options...
mwiener2 Posted January 24, 2013 Share Posted January 24, 2013 Propane's octane as rated in the USA would be around 105. The rest of the world would call it 112 octane. LPG cannot "gel" My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
frank_ster Posted January 24, 2013 Author Share Posted January 24, 2013 ^ agreed propane at low tempertures will simply have low boil pressure Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
mwiener2 Posted January 24, 2013 Share Posted January 24, 2013 can you do a propane / cng / gasoline vehicle? My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
ehsnils Posted January 24, 2013 Share Posted January 24, 2013 Just don't confuse CNG with Propane, different pressures... As I stated earlier. CNG/LNG are Methane. And Propane is often mixed with Butane to some extent, so the "quality" may vary a bit, but not too bad, the worst problem is usually that Butane boils at around 0 degrees C (would be about 35F), which makes it a bit awkward in the winter. Link to comment Share on other sites More sharing options...
frank_ster Posted January 24, 2013 Author Share Posted January 24, 2013 can you do a propane / cng / gasoline vehicle? would require separate tanks and to use the vapour system Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
mwiener2 Posted January 24, 2013 Share Posted January 24, 2013 I only ask cause automotive CNG refilling stations already exist... there's even one out by my shop My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
frank_ster Posted January 24, 2013 Author Share Posted January 24, 2013 yea cng is compressed to 3000 lbs or so while propane about 200 lbs depending on temperature so a better tank is needed Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
bigjweb Posted January 24, 2013 Share Posted January 24, 2013 Just don't confuse CNG with Propane, different pressures... As I stated earlier. CNG/LNG are Methane. And Propane is often mixed with Butane to some extent, so the "quality" may vary a bit, but not too bad, the worst problem is usually that Butane boils at around 0 degrees C (would be about 32F), which makes it a bit awkward in the winter. Link to comment Share on other sites More sharing options...
