BJommin Posted January 5, 2013 Share Posted January 5, 2013 Hello, so recently my check engine light came on and I had the codes read. The code that cam back was p1700 which is A/T throttle position sensor circuit malfunction. Anyone knows what this means? I'm not the most car literate person especially when it comes to sensors. Any recommendations I should try? Thanks. Ben Link to comment Share on other sites More sharing options...
Osei Posted January 6, 2013 Share Posted January 6, 2013 The DTC chart I have doesn't list any procedures without using Subaru's own scanner. I'd check the plug to the tps. Unplug and reinsert, making sure none of the contacts are bent. O. Link to comment Share on other sites More sharing options...
BJommin Posted January 6, 2013 Author Share Posted January 6, 2013 Okay I will but where exactly is the tips located? Link to comment Share on other sites More sharing options...
BJommin Posted January 6, 2013 Author Share Posted January 6, 2013 Oops meant Tps sorry Link to comment Share on other sites More sharing options...
Osei Posted January 6, 2013 Share Posted January 6, 2013 On the passenger side of the throttle body. Probably a black housing. Here is link to fsm. http://www.main.experiencetherave.com/subaru_manual_scans/ O.MSA5TCD95L5496.pdf Link to comment Share on other sites More sharing options...
monkeyposeur Posted January 6, 2013 Share Posted January 6, 2013 I posted the FSM procedure for testing the tps here: http://legacygt.com/forums/showthread.php/turbo-power-mode-issue-192937.html?p=4090441 Link to comment Share on other sites More sharing options...
