Evofai Posted December 4, 2012 Share Posted December 4, 2012 Hi, im new to installing these so I was wondering if I could possibly get a guide on how to install my HID's for my headlights. I have a 96 subaru legacy L AWD. Link to comment Share on other sites More sharing options...
spooln30 Posted December 5, 2012 Share Posted December 5, 2012 Do you have a kit should've came with instructions. I've installed a couple of kits and their easy to install. Should take only a hour. GL Link to comment Share on other sites More sharing options...
spooln30 Posted December 5, 2012 Share Posted December 5, 2012 Btw if you put "HID" in the search function you'll find probably tons of info. Link to comment Share on other sites More sharing options...
monkeyposeur Posted December 5, 2012 Share Posted December 5, 2012 What type of headlights do you have? USDM or JDM projectors? If you do not have JDM projectors then HIDs are not a good idea, illegal, and downright dangerous. Although you may have increased visibility at night you will blind/piss off oncoming traffic. Do you already have a kit? HIDs are really easy to install though. Most kits come with directions. All you do is connect the positive and negative wires to the battery, install the bulbs, zip tie the wiring harness and use sticky tape to secure the ballasts. Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted December 5, 2012 I Donated Share Posted December 5, 2012 Unless you didn't get the HID harness....then you wire them directly to the factory headlight plugs (not recommended) -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
underground000 Posted December 5, 2012 Share Posted December 5, 2012 remove dust cap, use a drill to cut dust caps if your car has one remove bulb install hid bulb run wire through dust cap plug spade from ballast to bulb connector use sticky tape to mount ballast need pics? search 5eat downshift rev match:) Powder coated wheels: completed:) Link to comment Share on other sites More sharing options...
monkeyposeur Posted December 5, 2012 Share Posted December 5, 2012 Here are some pics of my JDM projector HID install. I bought a DDM HID kit. This is by no means a complete DIY. I do not show how to wire your JDMs or do the UDSM conversion, or a lot of other stuff. Step 1: Convert your JDMs to the USDM light pattern. I followed the DIY posted by my esteemed buddy eekay: http://legacygt.com/forums/showthread.php/diy-jdm-headlight-blackout-and-usdm-light-pattern-conversion-127120.html Step 2, 3, 4 etc: Remove your headlights and grill. Mark the inner diameter of your rubber HID housing with dividers. Drill out the material inside the marked circle. Clean it up with a knife. I attached the power source thingy to the battery, a ballast below that and the other ballast below the passenger side headlight. I utilized an existing bolt hole for the passenger side along with some sticky tape. I zip tied the harness to whatever was convenient. Plug in some crap and enjoy your legal HIDs. Link to comment Share on other sites More sharing options...
Evofai Posted December 5, 2012 Author Share Posted December 5, 2012 remove dust cap, use a drill to cut dust caps if your car has one remove bulb install hid bulb run wire through dust cap plug spade from ballast to bulb connector use sticky tape to mount ballast need pics? search This helped a lot, thank you. And no the kit didnt come with an instillation directions lol. But yeah it was very simply. Link to comment Share on other sites More sharing options...
Baddog Posted December 7, 2012 Share Posted December 7, 2012 What type of headlights do you have? USDM or JDM projectors? If you do not have JDM projectors then HIDs are not a good idea, illegal, and downright dangerous. Although you may have increased visibility at night you will blind/piss off oncoming traffic. Do you already have a kit? HIDs are really easy to install though. Most kits come with directions. All you do is connect the positive and negative wires to the battery, install the bulbs, zip tie the wiring harness and use sticky tape to secure the ballasts. Just like BMW's. Weird. Link to comment Share on other sites More sharing options...
