bmglaude Posted December 1, 2012 Share Posted December 1, 2012 2006 LGT AT, 85K, Invidia Catless DP and UP, VF52 Turbo, Magnaflow CB Exhaust, IPR TMIC with suspension, brake and lighting upgrades (Angel Eyes by LightWerkz). Looking for some suggestions: I was just told me engine is toast, cylinder compression tested results for the passenger side was 130 front and 120 rear. I'm not sure exactly what that means so not sure if I should have a shop tear apart the engine to fully diagnose, search for a used engine to swap, or just try selling the car as is. The car is in excellent shape. Thoughts? Link to comment Share on other sites More sharing options...
need bb Posted December 1, 2012 Share Posted December 1, 2012 Need some more info. Compressions of 120 are not that bad. Link to comment Share on other sites More sharing options...
bmglaude Posted December 1, 2012 Author Share Posted December 1, 2012 Really? Ok, what type of information do you need? I'd love to get some help on this, thanks for the reply! Link to comment Share on other sites More sharing options...
BDII Posted December 1, 2012 Share Posted December 1, 2012 you have 4 cylinders. List each cylinder and the coinciding compression. Also tell us 1. where you took the car to get looked at 2. why you had a compression test in the first place 3. what CEL's did you have Need forum help? Private Message legGTLT Link to comment Share on other sites More sharing options...
bmglaude Posted December 1, 2012 Author Share Posted December 1, 2012 Yes, 4 cylinders and as mentioned above the 130 was the compresson of the passenger side front and 120 was for the passenger side rear. The shop didn't bother testing the drivers side becuase he considered it toast. I performed a compression test as a recommendation from a subaru technician based on the recent history car. A few weeks prior one of my plugs was found to be banged up and the associated coil pack was burned. This was found after I punched it then it started skipping at high rpms and started driving like shit and idling very low. When this happened my car has a strong smell of gas. The plugs and coil pack were changed out and the car seemed to drive fine for a few more weeks until this recent incident. This recent incident happend after driving fairly aggressive. The car seeemed fine then when I slowed down to pull into my driveway the car died and I couldn't get it to start again. I finally was able to get it to start and pulled it in. The next morning the car seemed to drive ok agian during a easy test drive, then again I slowed down to pull into a driveway and it died, I started it back up and it smoked quite a bit. I did not recieve any CEL's? Link to comment Share on other sites More sharing options...
BDII Posted December 1, 2012 Share Posted December 1, 2012 Test all 4 cylinders and report back. a 10psi variance is nothing. Need forum help? Private Message legGTLT Link to comment Share on other sites More sharing options...
bmglaude Posted December 1, 2012 Author Share Posted December 1, 2012 Isn't 30psi variance an isssue? I though the tolerance was 5% and the spec. was 150? Link to comment Share on other sites More sharing options...
BDII Posted December 2, 2012 Share Posted December 2, 2012 Was the motor warm or cold? Need forum help? Private Message legGTLT Link to comment Share on other sites More sharing options...
EJ25subie05 Posted December 2, 2012 Share Posted December 2, 2012 a good shop wouldn't consider the other two cylinders toast they would check to make sure. do what BDII said and get the other two checked out then report back. Link to comment Share on other sites More sharing options...
bmglaude Posted December 2, 2012 Author Share Posted December 2, 2012 Ok, I'll get the car towed to another shop. I'm not positive if the test was performed when the engine was warm or cold. Could a failed compression test also indicate a blown head gasket? Link to comment Share on other sites More sharing options...
bmglaude Posted December 2, 2012 Author Share Posted December 2, 2012 Anyone one have suggestions for a good shop in RI/Southern MA? Link to comment Share on other sites More sharing options...
claymore_6r Posted December 2, 2012 Share Posted December 2, 2012 Bring it to Alberto at Motive auto work...he probably could figure it out. Link to comment Share on other sites More sharing options...
Motive Auto Works Posted December 2, 2012 Share Posted December 2, 2012 Had a very similar issue on another LGT - txt or call if you need any advice - 978-317-1804 ;-) Link to comment Share on other sites More sharing options...
