LegacyKid5 Posted November 30, 2012 Share Posted November 30, 2012 Alright, I'm looking into getting hella supertone horns and I'm trying to decide whcih relay harness to go with. I'm not extremely electrical savvy, but I had read a bunch about the subimod harness being improperly wired due to the 4 pin issue. Now they have a note on their website saying: Subimods.com has now started including 5 pin relays with there harnesses, why? Hella includes with every set of horns a 4 pin relay, we construct our harness to only work with a 5 pin relay. If a 4 pin relay is used with our harness it could cause your horns to remain powered even when the car is off, when they should only be engergized when the horn is pushed. Any customers having this issue please contact us for a new relay So my question is should I go with the subimods harness or the AZP? Link to comment Share on other sites More sharing options...
nstg8r Posted November 30, 2012 Share Posted November 30, 2012 Alright, I'm looking into getting hella supertone horns and I'm trying to decide whcih relay harness to go with. I'm not extremely electrical savvy, but I had read a bunch about the subimod harness being improperly wired due to the 4 pin issue. Now they have a note on their website saying: Subimods.com has now started including 5 pin relays with there harnesses, why? Hella includes with every set of horns a 4 pin relay, we construct our harness to only work with a 5 pin relay. If a 4 pin relay is used with our harness it could cause your horns to remain powered even when the car is off, when they should only be engergized when the horn is pushed. Any customers having this issue please contact us for a new relay So my question is should I go with the subimods harness or the AZP? I'm using the Subimods harness with the 5-pin relay with no issues. Also using the Subimods horn bracket. Link to comment Share on other sites More sharing options...
I Donated bucko3the7man Posted November 30, 2012 I Donated Share Posted November 30, 2012 http://legacygt.com/forums/showthread.php/hella-supertone-install-walk-through-w-pics-22102.html Wire them up yourself and save your money Link to comment Share on other sites More sharing options...
