srgdrum Posted November 26, 2012 Share Posted November 26, 2012 Hey everyone. Long time no speak. Now for the question. If during the timing belt swap if either side cam gears were not perfectly lined up (say one tooth off) that would be a very real and immediately noticeable problem correct? Car would throw Cel right or run like crap? I did the belt job spark plugs and water pump over the weekend and have put 90 miles on the car in about 8 starts. Seems to run like a champ. No cels, no noticeable issues other than it justs seems louder in the engine bay. Ticking and whirring. Perhaps I'm just paranoid as that was the biggest job I've ever tried to tackle. Any input is greatly appreciated. Thanks! Link to comment Share on other sites More sharing options...
Max Capacity Posted November 26, 2012 Share Posted November 26, 2012 If you haven't had a CEL by now your ok. Did you rotate the engine by hand 3 times before you put the covers on ? The marks should line up every time when you do that. Not the belt marks all you worry about are the gear marks. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
srgdrum Posted November 27, 2012 Author Share Posted November 27, 2012 No. I didn't turn it over. Dipshit move on my part. I researched the hell out of this and didnt see that tip. In retrospect it seems pretty much a no brainer. Thanks for your quick response max. Much appreciated! Link to comment Share on other sites More sharing options...
Max Capacity Posted November 27, 2012 Share Posted November 27, 2012 Check post 26. I talk about there. http://legacygt.com/forums/showthread.php/replacing-timing-belt-94193.html 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
srgdrum Posted November 27, 2012 Author Share Posted November 27, 2012 Yup. You sure did! and I clearly missed it. Btw my 06 didn't have the timing belt guides at all. This forum is a great resource! Link to comment Share on other sites More sharing options...
Max Capacity Posted November 27, 2012 Share Posted November 27, 2012 No guides ? I wonder if the last person who replaced the belt, left them out. Did you buy the car used ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
srgdrum Posted November 27, 2012 Author Share Posted November 27, 2012 Nope. I bought the car new. Its an 06. There are def no guides at all! I took some reference pics with my phone but its tough to see. Link to comment Share on other sites More sharing options...
MAP Posted November 28, 2012 Share Posted November 28, 2012 I remember reading somewhere that only the engines attached to manual transmissions had those guides. Cars with the 5EAT didnt. Link to comment Share on other sites More sharing options...
srgdrum Posted November 28, 2012 Author Share Posted November 28, 2012 Well there you go! Confirmed: no guides on my 06 5eat lgt. Thanks guys! Link to comment Share on other sites More sharing options...
