jduani Posted November 24, 2012 Share Posted November 24, 2012 Hey Guys did some searching and i can not seem to find an answer. I currently have a 07 Spec B and i have a ton of fun mods on it. I want to through launch control and FFS shifting on it as well and i was looking into the Tiny Wrex patches. I have the ROM ID of A2UG000L. I can not seem to find anything that will work for that. Does matter? Could I use a patch that is slightly different like an A2UG000G (07 STi). Any help would be great... THANKS! Link to comment Share on other sites More sharing options...
bnguyenbb6 Posted November 24, 2012 Share Posted November 24, 2012 NSFW should be here soon. I think he may be the only one that has it right now on an LGT. Link to comment Share on other sites More sharing options...
NSFW Posted November 25, 2012 Share Posted November 25, 2012 You rang? I don't think it's a good idea to flash images other than ones that were made for your car. It might work, but it might brick your ECU. I made an LC/FFS/SD patch for A2WC522N and 522S (05 LGT/OBXT MT) but haven't done any others and don't have time to do more (maybe in a few months but I'm not promising). But there's a guy at RomRaider who picked up some of my changes, and added a bunch more cool stuff, and has applied it to a bunch of different ECUs. You might be able to get him to create a version for you as well. You're probably going to end up with speed-density as well since there's no point in porting over just the LC/FFS stuff (especially since someone's eventually bound to ask for SD as well), but the speed-density feature will be disabled by default so don't worry about it. http://www.romraider.com/forum/viewforum.php?f=37 http://www.romraider.com/forum/viewtopic.php?f=37&t=8143 Link to comment Share on other sites More sharing options...
fahr_side Posted November 25, 2012 Share Posted November 25, 2012 You could also request Tinywrex to patch your ROM. Obligatory '[URL="http://legacygt.com/forums/showthread.php/2008-gh8-238668.html?t=238668"]build thread[/URL]' Increased capacity to 2.7 liters, still turbo, but no longer need spark plugs. Link to comment Share on other sites More sharing options...
jduani Posted November 27, 2012 Author Share Posted November 27, 2012 Fahr_side I was thinking that. NSFW how hard would it be to make on my own? I am an electrical engineering major with background in programming. Could I theoectialy do it or it is not worth the risk? Link to comment Share on other sites More sharing options...
