acooken Posted November 24, 2012 Share Posted November 24, 2012 Replaced timing belt and it runs fine while eng. is cold no eng. codes. Once eng. gets to operating temp set #1 cyl misfire code shows up and engine chugs. Any ideas? Link to comment Share on other sites More sharing options...
Stasis Posted November 24, 2012 Share Posted November 24, 2012 You've given the fault, but not what car it is or engine etc Link to comment Share on other sites More sharing options...
acooken Posted November 25, 2012 Author Share Posted November 25, 2012 97 legacy 2.2 engine.the original timing belt broke while driving it.. Link to comment Share on other sites More sharing options...
johnegg Posted November 25, 2012 Share Posted November 25, 2012 bent valves Link to comment Share on other sites More sharing options...
acooken Posted November 25, 2012 Author Share Posted November 25, 2012 Let me ask this. While orienting the cams the drivers side cam had a springy feel to it as i would bring the mark on pulley to 12 o'clock position if I wasn't careful it would snap fwd or backward 30 degrees. Passenger side was nothing like this. So is that normal or definitely bent valves. Link to comment Share on other sites More sharing options...
DOHCEJ22E1 Posted November 25, 2012 Share Posted November 25, 2012 Let me ask this. While orienting the cams the drivers side cam had a springy feel to it as i would bring the mark on pulley to 12 o'clock position if I wasn't careful it would snap fwd or backward 30 degrees. Passenger side was nothing like this. So is that normal or definitely bent valves. The right side is spring loaded. The left side isn't. This is the same event for the dual cam EJs. If you have aligned the engine perfectly, got it to run in perfect timing, & you're still having engine problems, then as John says, you may have bent valves. Post up pics of how you're aligning the cam wheels. Link to comment Share on other sites More sharing options...
acooken Posted November 25, 2012 Author Share Posted November 25, 2012 Wish I had thought to take pics. I only hav a crude drawing. And I can't figure out how to attach pic to this post. It shows on passenger side cam the the notch on pulley is slightly to left of notch on case notch. The reason for that is the lines on belt r off by half a tooth on pulley. Thinking back guess I shouldnt hav focused so much on not so accurate marks but the the notches on pulley. All other lines matched up. For the most part. Link to comment Share on other sites More sharing options...
spooln30 Posted November 27, 2012 Share Posted November 27, 2012 Ive had cars at the shop that were interference engines with broken timing belts that didn't bend valves. Not saying it won't happen because in most cases they will bend when the belt breaks. One thing I haven't seen posted, if the valves were bent it would have a misfire all of the time, not just when the engine is at temp. Link to comment Share on other sites More sharing options...
acooken Posted November 27, 2012 Author Share Posted November 27, 2012 It may hav slight miss when cold. Definitely has miss when warm. Has normal driveablity and power when moving but idle quality is where we notice miss. P0301 misfire #1cylinder code shows up when we idle in gear. Last night we got out book and did tooth count. From crank center point mark to drivers cam. 40.5 teeth. Then to passengers side cam 44 gaps between teeth on belt. . The result r what I just mentioned in this post. I feel we're so close but its not right. Plugs all Look like good burn. Nothing very obviously wrong visually. Link to comment Share on other sites More sharing options...
acooken Posted November 27, 2012 Author Share Posted November 27, 2012 Generally speaking if we hav bent valve. What does that repair job cost at a shop. ? Just trying to figure out if car is worth that expensive of repair. Link to comment Share on other sites More sharing options...
spooln30 Posted November 28, 2012 Share Posted November 28, 2012 Cost of repairs will vary. It will not be cheap. The belt can be confusing to line up if it's your first time doing one. I have always had to set the LH intake cam gear off a tooth so when the tensioner was released all of the marks lined up. Otherwise if you have them lined up before the tensioner is released you will have one to two gears off a tooth. Most 4 cam engines are like this. Link to comment Share on other sites More sharing options...
acooken Posted November 28, 2012 Author Share Posted November 28, 2012 I only two cams to worry about but that seems to be enough for me. I was wondering if I need to back off left cam one tooth or move crank gear fwd one tooth. I still need to check where timing is with a warm engine. Link to comment Share on other sites More sharing options...
