claymore_6r Posted December 16, 2012 Share Posted December 16, 2012 Do you need spacer with Koni/epic or Koni/H-Tein to avoid saggy butt? Link to comment Share on other sites More sharing options...
AZP Installs Posted December 16, 2012 Share Posted December 16, 2012 Do you need spacer with Koni/epic or Koni/H-Tein to avoid saggy butt? Depends on your preference. I never ran spacers on my LGT wagon even with pinks on it. -Mike Paisan http://www.pbase.com/paisan/image/91072632.jpg http://www.pbase.com/paisan/image/145749898/original.jpg http://www.pbase.com/paisan/image/133406601.jpg http://www.whiteline.com.au/images/logos/perf1.jpg 11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts. Call directly as We carry almost every manufacturer now, so before you buy parts call us. Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) | T-1 Certified Amsoil Direct Jobber |AIM: AZP Installs "Race Tested, Enthusiast Approved!" Link to comment Share on other sites More sharing options...
ssbtech Posted May 20, 2013 Share Posted May 20, 2013 In the car game, everything is a compromise for the most part. Epics will not be as stiff and yield a better ride, but at the expense of that crisp handling etc. So it is more of a personal decision as to what setup is best for you. Our usual suggestion is Pinks are only for hard-core folks who drive hard all the time and/or track their car as the ride is significantly stiffer. -Mike Paisan I've just ordered the HDs but I'm wondering if I'm making the wrong choice here. I haven't picked springs yet. Roads here aren't full of potholes, but there's a lot of manhole covers and drains that aren't flush with the road surface, dips and bumps from where tree roots have shifted the pavement, etc... What factory suspension might the HDs/Pinks be comparable to? Cars I've driven include a 2013 Outback, 2013 Dodge RAM 1-ton, 2011 Mustang GT and I've found them all to ride well on our roads. Link to comment Share on other sites More sharing options...
Impatient Posted May 21, 2013 Share Posted May 21, 2013 Define comfort. Tires matter. Personally, I think Bilstein HD's are more comfy than KYB, except for blown marhmellow rear KYB's...on a perfectly smooth road. But I'm in an Outback, so what do I know. Can't comment on Koni's, but the adjustability sounds like a plus. I wouldn't be surprised if a bone stock spec B set of struts and springs wouldn't be cushier than a stock LGT setup...and should be direct bolt up....if you get the spec B tophats in the process. Link to comment Share on other sites More sharing options...
fahr_side Posted May 22, 2013 Share Posted May 22, 2013 Tough question. KYB IME has effective but unsophisticated damping... not very smooth on anything but the best roads. Koni is good in most situations but there is a certain combination of square-edged bump and road speed that really jars, regardless of the spring in use. Bilsteins seem buttery smooth by comparison but the big seals used in inverted struts mean springs with very low rates make seal stiction noticeable, so they beg for higher rates which again are uncomfortable on bad roads at low speeds. In the end you figure out there is a minimum speed for comfort which increases with spring rate. I used to use inverted KYB struts and Vogtland springs on my old GF Impreza... awesome at high speeds but death to kidneys under 80kph. On my cuurent GH8 I have Konis and OE GRF springs... very good comprise. Obligatory '[URL="http://legacygt.com/forums/showthread.php/2008-gh8-238668.html?t=238668"]build thread[/URL]' Increased capacity to 2.7 liters, still turbo, but no longer need spark plugs. Link to comment Share on other sites More sharing options...
ssbtech Posted May 22, 2013 Share Posted May 22, 2013 I've got the HDs on the way and I'm just waiting for confirmation on the correct springs in my other thread. Hopefully around town they're comfortable. Link to comment Share on other sites More sharing options...
SBT Posted May 23, 2013 Share Posted May 23, 2013 Epics will likely be your most comfortable and won't drop you to the point that you lose the stroke on the HDs. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
