Refuge Posted November 7, 2012 Share Posted November 7, 2012 So I am replacing my 05 MT DriveShaft. Someone told me to check and see if the later 4th generation rear differential and DriveShaft will work better. They said that the later design my be able to handle more torque. Link to comment Share on other sites More sharing options...
Max Capacity Posted November 7, 2012 Share Posted November 7, 2012 Last time I check a 2005-2009 is a 4th gen Legacy. But what do I know...I don't even have 8000 post here yet. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
bakabakablah Posted November 8, 2012 Share Posted November 8, 2012 Last time I check a 2005-2009 is a 4th gen Legacy. But what do I know...I don't even have 8000 post here yet. 05-09 may be considered to be one 'generation' but it isn't unusual for car manufacturers to put in a different part number for a car made towards the end of the generation as compared to one made at the beginning. An example of this is the air pump found on MY07+ Legacys... sure, the 05 is similar cosmetically but there are slight differences between the years. As for the OP's question, I'm sorry to say that I don't know. If no one responds with any useful info on the forums (and assuming you've already done a search), I can think of three ways to find out... a) Go to Fredbeanspart's website (or any similar site) and look at the parts catalog to see if there are any differences b) Ask some of the vendors on here (e.g. m sprank @ IP&T) c) Ask your dealership's parts department (that's what they're there for) Good luck with your search, and keep us updated. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted November 8, 2012 Share Posted November 8, 2012 Are you looking for this below? Here is the link: http://www.subarupartsforyou.com/cp_partdetail.php?partid=17994 Looks like same part number across the years, BUT they do ask for your VIN. So there may be some differences between the years within that gen. Edit: you'll see that the part number ends with 2 Xs. That may mean that the part number differs slightly depending on the MY. Link to comment Share on other sites More sharing options...
Max Capacity Posted November 8, 2012 Share Posted November 8, 2012 The difference is automatic or manual tanny's, (6 speed or 5 speed). And yes, most of us know the 07-09's have the air pump. There are also other small differences, but that's not what he asked about. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
xt2005bonbon Posted November 8, 2012 Share Posted November 8, 2012 The difference is automatic or manual tanny's, (6 speed or 5 speed). You are probably right then, since one can identify trans type by checking our car's VIN. Link to comment Share on other sites More sharing options...
bakabakablah Posted November 8, 2012 Share Posted November 8, 2012 The difference is automatic or manual tanny's, (6 speed or 5 speed). And yes, most of us know the 07-09's have the air pump. There are also other small differences, but that's not what he asked about. I was merely trying to give an example of how things don't stay the same within a model generation as you seemed to imply. Link to comment Share on other sites More sharing options...
Refuge Posted November 8, 2012 Author Share Posted November 8, 2012 LOL @ GearHead and his 8 posts & Bakabakablah I see! I didnt specify that i was looking to put in a 2008 drive shaft and rear diff into a 2005 LGT Link to comment Share on other sites More sharing options...
Refuge Posted November 9, 2012 Author Share Posted November 9, 2012 So one call to the dealership said that in 2006 SOA changed the part number (and part I presume). This part apparently super-cedes the original Drive Shaft sold to me in 2005 on this car. Maybe they noticed something weak on the 05 part... I have no idea Link to comment Share on other sites More sharing options...
.blackgt. Posted November 9, 2012 Share Posted November 9, 2012 probably not Link to comment Share on other sites More sharing options...
