KuntryQuestTSi Posted October 29, 2012 Share Posted October 29, 2012 Will a direct bolt on tubro for a 08 STi bolt on to my 05 LGT? Its a 20G I'm looking at. Also, my TGV's are gone if it matters. Link to comment Share on other sites More sharing options...
Max Capacity Posted October 29, 2012 Share Posted October 29, 2012 I'm not positive, by if you go with a fmic it will be. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
KuntryQuestTSi Posted October 29, 2012 Author Share Posted October 29, 2012 I am front mounted. ( that sounds wrong ) Link to comment Share on other sites More sharing options...
spec.B Dream Posted October 29, 2012 Share Posted October 29, 2012 With the right front mount, it will fit. There is still the difference between the Legacy's VF40 bolt-on intercooler setup and the STi's clamp-on intercooler setup. The RacerX FMIC comes with pipes for both connections. Other FMICs do as well, you just need to make sure you have the right pieces. Link to comment Share on other sites More sharing options...
KuntryQuestTSi Posted October 29, 2012 Author Share Posted October 29, 2012 It will bolt on to the car though correct? My down pipe will work still? All I'll really need is a charge pipe? Link to comment Share on other sites More sharing options...
Nrw Posted October 29, 2012 Share Posted October 29, 2012 yes Link to comment Share on other sites More sharing options...
KuntryQuestTSi Posted October 29, 2012 Author Share Posted October 29, 2012 Thanks much guys. Link to comment Share on other sites More sharing options...
