GreenGoblin Posted October 27, 2012 Share Posted October 27, 2012 This should be pretty straight forward but for some reason the front passenger axle won't stay put in the transmission. It slides in but will not snap in place. The driver side seems ok. What am I missing??? Link to comment Share on other sites More sharing options...
BAC5.2 Posted October 27, 2012 Share Posted October 27, 2012 If you have stubs on the transmission (female axles), you need to insert the double roll pin. If you have stubs on the axles (female transmission), make sure the circlip is on the axle groove. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
jamal Posted October 28, 2012 Share Posted October 28, 2012 Assuming this is for your 97gt, the stub is held in with a cir-clip. You would have to take the trans case apart to remove or install it. The axle is held onto the stub with a roll pin. Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted October 28, 2012 I Donated Share Posted October 28, 2012 assuming this is for your 97gt, the stub is held in with a cir-clip. You would have to take the trans case apart to remove or install it. The axle is held onto the stub with a roll pin. +1 -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
GreenGoblin Posted October 28, 2012 Author Share Posted October 28, 2012 Assuming this is for your 97gt, the stub is held in with a cir-clip. You would have to take the trans case apart to remove or install it. The axle is held onto the stub with a roll pin. Thanks for confirming my suspicion that the roll pin on the axle was possibly missing. I'll remove the axle tomorrow to get a better look. Does anyone have pics of this setup Link to comment Share on other sites More sharing options...
GreenGoblin Posted October 28, 2012 Author Share Posted October 28, 2012 Found some more info here: http://www.subaruoutback.org/forums/66-problems-maintenance/23368-ring-clips-cv-joint-axle.html Looks like I need a c-clip at the end of the axle stub. It might have fell off when we were doing other repairs. The trans whines really loud over 50mph and a loose axle is just plain dangerous. Link to comment Share on other sites More sharing options...
