indragz Posted October 26, 2012 Share Posted October 26, 2012 I installed h&r lowering springs and gr-2 struts with new kyb strut mount 2 days ago. Ever since then my suspension has been creaking. Is that normal? Link to comment Share on other sites More sharing options...
SBT Posted October 26, 2012 Share Posted October 26, 2012 More info would be helpful. Where is the creaking coming from? Front, rear, top, bottom, left, right, during turns, while stopping, while accelerating? Anything else changed, loosened, replaced during the install? - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
FJuan Posted October 26, 2012 Share Posted October 26, 2012 In most cases on new suspensions, the creaking is coming from the spring perches as the spring rubs against it while going over rough roads or bumps (even turning). Some of the vendors sell rubberized sleeves that fit over the ends of the springs to prevent this. One way to check this is pull off one of the shocks that is making the sound. Pop the spring off and inspect the spring perch, if there are rub marks then this was the issue. If not, it could be swaybar bushings or LCA bushings. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
SBT Posted October 27, 2012 Share Posted October 27, 2012 Some of the vendors sell rubberized sleeves that fit over the ends of the springs to prevent this. Any link to these sleeves. Been looking for a few sets for some installs I'm doing. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
indragz Posted October 28, 2012 Author Share Posted October 28, 2012 I replaced the strut, springs and strut mount nothing else, because I didn't see any damage on the rubbers so I just reused the stock ones. And the creaking is coming from the front on both sides. It creaks when I'm driving in low speeds like when I'm parking or leaving my parking spot. Link to comment Share on other sites More sharing options...
SBT Posted October 28, 2012 Share Posted October 28, 2012 So it's creaking and not clunking. Creaking could just be that the sway bar bushings need grease. Could also be Lower Control Arm Bushings that are at/beyond service life and need replaced, or even endlinks that are bad. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
FJuan Posted October 29, 2012 Share Posted October 29, 2012 Any link to these sleeves. Been looking for a few sets for some installs I'm doing. Couldn't remember which one sells them, but here's a few links. Tein - http://www.tein.com/products/silencer_rubber.html Eibach - http://pitstopusa.com/c-421031-springs-coil-spring-accessories-coil-spring-sleeves.html My wife's balls are delicious. Link to comment Share on other sites More sharing options...
dark_thorns Posted October 31, 2012 Share Posted October 31, 2012 have you used kyb struts before? i need to replace my rear struts and was looking at the kyb gr-2. what else would i need to replace when doing the struts? the spring still looks fine so i was just going to do the strut, strut mount, bellows, and i was gonna go ahead and do the cv axles while i was at it. Link to comment Share on other sites More sharing options...
FJuan Posted October 31, 2012 Share Posted October 31, 2012 ^^ That's exactly what needs to be replace for a proper strut/shock replacement. Strut, mounts and bellows. Most people don't realize that the mounts get worn out too and may cause a clunking sound once the rubbers wears out. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted October 31, 2012 Moderators Share Posted October 31, 2012 no real reason to replace the bellows (dust jacket)? I'm reusing mine while rebuilding my koni inserts and they're fine. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
FJuan Posted October 31, 2012 Share Posted October 31, 2012 ^^ True, also not a bad idea to replace the bump stop too, depending how old and crusty they are. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
indragz Posted November 2, 2012 Author Share Posted November 2, 2012 Im still not sure why my suspension is creaking but now after driving in hurricane sandy my suspension doesn't creak anymore. I guess is the swaybar bushings needed lubricants/grease? Link to comment Share on other sites More sharing options...
FJuan Posted November 2, 2012 Share Posted November 2, 2012 That's one way to cure a creak, just drive through a storm. j/k My wife's balls are delicious. Link to comment Share on other sites More sharing options...
Toallhisdoom Posted November 2, 2012 Share Posted November 2, 2012 have a pic of it on the new springs? kinda wanna see how this setup looks. Link to comment Share on other sites More sharing options...
