Minnesota Bob Posted November 9, 2012 Author Share Posted November 9, 2012 Hello Johnegg, I haven't checked the timing or compression. I will try checking the timing this weekend. Link to comment Share on other sites More sharing options...
twisty Posted November 9, 2012 Share Posted November 9, 2012 I checked my fuel pressure and found that I had 38-42 psi at idle and when I pinched down the return line the pressure spiked up to almost 70 psi. I took it out for a ride and ran the fuel pressure guage out from under the hood so I could view it while driving. The car acted up as always...but the fuel pressure remained at near 40 psi. I am sure I can rule out any kind of fuel pressure issues. I also replaced the plugs and wires with Subaru items with no luck. I talked to another shadetree mechanic about this problem. He suggested that I may have a problem with the torque converter locking up too soon. If the torque converter (tc) locks up at a low rpm it would cause the engine to bog down. It would also answer the question as to why the car accelerates hard when under full throttle (the tc would unlock). Is there a way to run the trans with the lock up portion of the tc permanently unlocked? IIRC, doing the "power mode" mod will keep it from locking in. Link to comment Share on other sites More sharing options...
1055 Posted November 9, 2012 Share Posted November 9, 2012 Grounding a single wire should keep it from locking up. Ill have to look at the pinouts to tell you which circuit exactly but i remember seeing it done on several occasions in the past. Its actually a common 'mod' on early xj jeeps with bigger tires. They develop a clunk/thud from all the extra drivetrain load due to the TC. Link to comment Share on other sites More sharing options...
twisty Posted November 14, 2012 Share Posted November 14, 2012 Link to comment Share on other sites More sharing options...
Cannman Posted November 27, 2012 Share Posted November 27, 2012 Any progress on your problem? I'm having the same exact problem, and your first post sounds like the last year of my life, haha. I've changed the MAF, Knock sensor (twice), Throttle Body, TPS, Plugs + Wires... still nothing. Even have a ground kit installed in case that was the problem. Link to comment Share on other sites More sharing options...
