chucktoo Posted July 22, 2005 Share Posted July 22, 2005 Has anyone found longer brake lines for an OBXT ? Even though mine is lowered it is not clear the LGT lines are long enogh ? We are getting ready to install StopTech's front and rear with the 6 mt drive train and this seemed like a good time to do brake lines. If not OBXT lines what are your favorite LGT lines ? Link to comment Share on other sites More sharing options...
Deer Killer Posted July 22, 2005 Share Posted July 22, 2005 I'd think lines for an OBXT would be too long for you? With all the work you are doing you might as well have someone make up the right lengths, no? Link to comment Share on other sites More sharing options...
inthedeck Posted July 22, 2005 Share Posted July 22, 2005 what kinda 6MT you puttin' in there? An STi one with the DCCD? Link to comment Share on other sites More sharing options...
Limeydriver Posted July 22, 2005 Share Posted July 22, 2005 Front Goodrich or Cobb SS lines fit the front no problem. Rear SS brake lines (that fit bout of the box) do not exist for the Outback. There are two problems. 1. Too short 2. The Outback has a strange short coupling from the rigid pipe which causes the SS lines to leak. If you talk to the guys at P&L Motorsports they fabricated custom rear rigid lines for me so the stock Cobb SS lines would fit. Link to comment Share on other sites More sharing options...
chucktoo Posted July 22, 2005 Author Share Posted July 22, 2005 Thanks for the leads. It is a JDM non-DCCD 6 mt with R-180 rear - we could not figureout how to make DCCD work right without a speedo signal . We have the speedo signal on the CAN bus from the ABS. Link to comment Share on other sites More sharing options...
sduford Posted July 25, 2005 Share Posted July 25, 2005 What's the verdict on pads and lines for the OBXT, anything available now? Sylvain www.digitalfotographer.com - Audi Q5 Club - MB-GLK Club Link to comment Share on other sites More sharing options...
Limeydriver Posted July 26, 2005 Share Posted July 26, 2005 2004 WRX pads fit the front calipers, so do the 2004 WRX rotors. Cobb SS lines fit the front. I have carbotech bobcats on the front along with carbotech slotted rotors - works very well. Still no progress on the rears. Definitely not WRX calipers/rotors on the back. Link to comment Share on other sites More sharing options...
sduford Posted July 26, 2005 Share Posted July 26, 2005 Thanks Limey. And changing just the fronts doesn't cause any front/rear balance issues? Sylvain www.digitalfotographer.com - Audi Q5 Club - MB-GLK Club Link to comment Share on other sites More sharing options...
PGT Posted July 26, 2005 Share Posted July 26, 2005 FYI - the Cobb SS lines have issues on the rear of the LGT. The fitting is too large for the hardened mount....we called Goodridge to verify size (they build these to Cobb's specs) and they confirmed the issue. I am hugely dissappointed as these were a premium over std. Goodridge lines....in my mind, they should be perfect given Cobb's focus on Subaru. Also, they didn't include new clips like Goodridge normally sends with lines. According to Cobb, you are supposed to re-use the stock ones. The solution was simple enough, though time-consuming. The holes in the hardened steel needs to be opened up. Once this is done, the lines are secure but I expected more of Cobb products. The difference with the Cobb SS lines is that they have a clear PVC jacket over the stainless mesh and each set are pressure tested. Mastro sells a similar private label Goodrich product. Link to comment Share on other sites More sharing options...
Limeydriver Posted July 26, 2005 Share Posted July 26, 2005 And changing just the fronts doesn't cause any front/rear balance issues? No things are still fine. It makes a big difference. However the slotted rotors do increase the noise a bit when braking Link to comment Share on other sites More sharing options...
