Twyzted Posted September 26, 2012 Share Posted September 26, 2012 Does anyone know if the L wagons have the same spring rate as the L sedans? I would assume the wagons would have a heavier spring rate vs the sedans. Any info would be a big help. Thanks. Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted September 27, 2012 I Donated Share Posted September 27, 2012 Why does it matter? Generally wagon / sedan parts are interchangeable with each other. Tons of people have done it with no complaints. -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
Twyzted Posted September 27, 2012 Author Share Posted September 27, 2012 I work for a salvage yard and am replacing my rear struts with used parts (because of cost vs new). Our computer inventory system says the parts interchange but there are different spring rates available and does not specify what they are or which cars are different. If the L wagons have a heavier spring, I will use them instead of sedan springs. Link to comment Share on other sites More sharing options...
twisty Posted September 28, 2012 Share Posted September 28, 2012 a wagon has much heavier rear ends, you can see that by looking at them. there are spacers available if the wagon gets "saggy butt". id say do it, wait a month and take a look at where the rear is sitting. if its fine to you, go with it. if its looking saggy, get some spacers on that sucker. Link to comment Share on other sites More sharing options...
Twyzted Posted September 30, 2012 Author Share Posted September 30, 2012 I have a sedan. I want the heavier springs to compensate for my stereo system and always having passengers in the car. My wheels have a wide offset and I rub just a little when loaded. I'm hoping heavier springs will keep my quarters off my tires. Link to comment Share on other sites More sharing options...
