cybaster Posted September 26, 2012 Share Posted September 26, 2012 Hi everyone, long story short, i did all the following things at once: - install new coilovers - changed rotors/brake pads - installed new front axles (replaced broken CV boot) so I was driving home from my brother's garage (about a 2 minute drive) and I hear some mild rubbing noise (that increases with speed) Is that an issue with bedding the new brakes? Or more importantly are there anything that may cause this rubbing noise, i don't want to start the bedding process before I can make sure i don't f* things up. Link to comment Share on other sites More sharing options...
Max Capacity Posted September 26, 2012 Share Posted September 26, 2012 Make sure the backing plate is not hitting the rotor. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
cybaster Posted September 26, 2012 Author Share Posted September 26, 2012 so just to confirm having not bedded the pads and rotor shouldn't make that horrible sound then? Link to comment Share on other sites More sharing options...
cybaster Posted September 26, 2012 Author Share Posted September 26, 2012 Thanks for the info, I've bent back the dust shields, and so far it seems to be more or less silent. I also think the sound may be partly due to the new brakes. Link to comment Share on other sites More sharing options...
xero287 Posted September 27, 2012 Share Posted September 27, 2012 Did you reset your parking brake correctly? It could be dragging. Link to comment Share on other sites More sharing options...
cybaster Posted September 27, 2012 Author Share Posted September 27, 2012 no i haven't reset the parking brake, thanks for the heads up, i'll check that out. Link to comment Share on other sites More sharing options...
