xero287 Posted September 27, 2012 Share Posted September 27, 2012 I usually just hit the car in front of me to engage my air brakes. Link to comment Share on other sites More sharing options...
specialB Posted September 27, 2012 Share Posted September 27, 2012 I was thinking about while driving home with another 400lbs of lime in the car. Are you a mason by any chance or you just decomposing a lot of bodies? Sent from my DROID RAZR using Tapatalk 2 Link to comment Share on other sites More sharing options...
adreyna Posted September 27, 2012 Share Posted September 27, 2012 But if you have to drive further using gas because the engine braking slows you down more than coasting, isn't that going to be about the same averaged out. I was thinking about while driving home with another 400lbs of lime in the car. I think it depends on the situation. I learned what SBT said about leaving it in gear is better for the engine and save gas, than in neutral, in an episode of top gear uk. Link to comment Share on other sites More sharing options...
Blue 07 Gt Posted September 27, 2012 Share Posted September 27, 2012 In my auto's I just brake, and in my manuals I usually down shift. Don't ask me why, it's just what I do. Link to comment Share on other sites More sharing options...
Max Capacity Posted September 27, 2012 Share Posted September 27, 2012 Probably, but I don't always engine brake. I assess the situation I'm in when slowing down and I'll either engine brake or coast in neutral. One example would be a freeway exit ramp that's at an incline. If I engine brake, I won't make it to the top so I tend to put it in neutral and coast. That's pretty much what happens in the real world for me too. I assess what the road ahead is ans what traffic is like. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Max Capacity Posted September 27, 2012 Share Posted September 27, 2012 Are you a mason by any chance or you just decomposing a lot of bodies? Sent from my DROID RAZR using Tapatalk 2 No, it's pillitized lime for the lawn, at least that's what I tell anyone that ask... FWIW, it's $3.00 per 40lb bag at Tractor Supply for those guy's who have lawns. I've put down 1200lbs in the past week or so. I tried leaving the tranny in 5th while rolling down the hills on the DD today. Way to much driveline noise with a 17lb FW and urthane bushings. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Dbl_D718 Posted September 27, 2012 Share Posted September 27, 2012 Edit: Nvm, I am now educated on the topic. MODS: PW TMIC, Cobb catted DP, HKS cat-back, AVO filter, Bren e-tune; Konis/Epics, Advan RCII Link to comment Share on other sites More sharing options...
Matt166 Posted September 28, 2012 Share Posted September 28, 2012 heel@toe, every change, even in traffic.............. Link to comment Share on other sites More sharing options...
aac0036 Posted October 5, 2012 Share Posted October 5, 2012 I leave it in whatever gear I'm currently in to engine brake while I'm braking and then put it in neutral before it hits the stall point. Ditto. Maybe downshift if I'm going really slow and nobody's behind me. Link to comment Share on other sites More sharing options...
