bigritz Posted September 17, 2012 Share Posted September 17, 2012 Ok so here is the deal I have found a to good to be true or pass up deal on some STi prodrive wheels and need to figure out how much the cost would be to go to 5x114? does anyone have any insight as to where to get 5x114 , are adapters efficient or do i lose perfomance there? Thanks in advance for any and all help:cool: Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted September 17, 2012 Moderators Share Posted September 17, 2012 I believe adapters run somewhere around $150. You'll push the wheels out pretty far by doing this and may run into clearance issues. How wide are the wheels, and how wide will your tires be? Also plan on replacing your wheel bearings more often, doing this will stress them more than usual and may cause failure. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
Drift Motion Posted September 17, 2012 Share Posted September 17, 2012 prodrives are usually 17x7 +51 so with a 15mm adapter, you'll be just fine but spacers are pretty stupid tho Link to comment Share on other sites More sharing options...
bigritz Posted September 17, 2012 Author Share Posted September 17, 2012 the wheels are 18x8.5 +53 Link to comment Share on other sites More sharing options...
bigritz Posted September 17, 2012 Author Share Posted September 17, 2012 Well what does the general genious of the forum suggest pass on the wheels or find the full hubs the wheels a $450 Link to comment Share on other sites More sharing options...
mwm5094 Posted September 17, 2012 Share Posted September 17, 2012 Theres no way you can fit 18x18.5 Link to comment Share on other sites More sharing options...
bigritz Posted September 17, 2012 Author Share Posted September 17, 2012 Theres no way you can fit 18x18.5 hahahahaha you caught me !! that was an error 18x8.5 sorry guys Link to comment Share on other sites More sharing options...
joeblow Posted September 17, 2012 Share Posted September 17, 2012 You will have to do some fender work with an 18x8.5+38 (which will be the offset if you go with the adapters). Definitely a roll, possibly a pull depending on what kind of negative camber you decide to run. I ran an 18x8.5 +48 on my LGT and had to run about -1.5 camber up front and roll the rears (with just natural camber, not camber kit) to keep rubbing to a minimum, so add another 10mm outboard, and you'll definitely need some work done. Long story short, it could cost you anywhere from $150 (just the adapters) up to $4-500 if you have to roll/pull the fenders, buy camber plates for the front and the rear camber kit for the rear on top of the adapters. And a hub swap will probably set you back quite a bit since you'll have to find the hubs and swap rotors, which I don't know if you'll find in LGT size with the new 5x114.3 pattern, along with all the other incidentals involved in a hub swap. It's cool; I'm with the band Link to comment Share on other sites More sharing options...
Bolksey85 Posted September 18, 2012 Share Posted September 18, 2012 I think it's been covered in the past that a hub swap is not an option due to something with the splines or something. Read here Link to comment Share on other sites More sharing options...
bigritz Posted September 19, 2012 Author Share Posted September 19, 2012 Well wont be going this route thanks for the input Link to comment Share on other sites More sharing options...
