kriptnite Posted September 16, 2012 Share Posted September 16, 2012 hello im new to the forum so i hope im putting this in the right spot.i have a 97 leg its awd but noticed it bucks and binds up when turning sharp like most 4x4s do when locked in is there nothing that slips when turning sharp or is it suposed to do that. Link to comment Share on other sites More sharing options...
SomethingWittyAsAUsername Posted September 16, 2012 Share Posted September 16, 2012 Bad news, broski. Welcome to the dying differential club. We meet on Thursday nights and talk about driving in slow circles in parking lots. Link to comment Share on other sites More sharing options...
Stang70Fastback Posted September 16, 2012 Share Posted September 16, 2012 Not necessarily a failing differential. It might be the center clutch pack that splits the power front-rear. You can diagnose it by putting a fuse in the little FWD fuse holder under the hood (it's in the upper left corner of the engine bay if you are looking into it.) It that solves the issue of binding in tight turns, then you know where the problem resides. Link to comment Share on other sites More sharing options...
johnegg Posted September 16, 2012 Share Posted September 16, 2012 auto trans or manual trans?? there is a big difference. Link to comment Share on other sites More sharing options...
kriptnite Posted September 16, 2012 Author Share Posted September 16, 2012 auto,there is a fuse in the fwd so someone i guess has already tried that?i might just remove the rear drive shaft.will i loose fluid if i do that? Link to comment Share on other sites More sharing options...
SpecBamf41 Posted September 16, 2012 Share Posted September 16, 2012 not sure. or you could remove the front axles because racecar http://scrapedcrusaders.files.wordpress.com/2012/06/driftlegacyfirsttimemay1920128.jpg BNR18g on 93oct Link to comment Share on other sites More sharing options...
Stang70Fastback Posted September 16, 2012 Share Posted September 16, 2012 auto,there is a fuse in the fwd so someone i guess has already tried that?i might just remove the rear drive shaft.will i loose fluid if i do that? Do you have a little 'FWD' light illuminated on your instrument cluster? Link to comment Share on other sites More sharing options...
johnegg Posted September 16, 2012 Share Posted September 16, 2012 i might just remove the rear drive shaft.will i loose fluid if i do that? . if you remove the whole thing you will lose fluid. if you just remove the rear section of the drive shaft you will be ok. just remove the long straight pipe from the center support back. 4 bolts and nuts on each end, 12mm. you have to remove the heat shields to get to it. Link to comment Share on other sites More sharing options...
kriptnite Posted September 16, 2012 Author Share Posted September 16, 2012 ok just removed rear shaft.drives great now.......should get better mpg now also.like i said there was a fuse already in the fwd but there is no lights on the cluster,should there be? Link to comment Share on other sites More sharing options...
DOHCEJ22E1 Posted September 17, 2012 Share Posted September 17, 2012 Yes. There is supposed to be a FWD light illuminated in red. Link to comment Share on other sites More sharing options...
kriptnite Posted September 17, 2012 Author Share Posted September 17, 2012 hmm may have a bad fuse in it.ill check it out.thx for the help guys Link to comment Share on other sites More sharing options...
johnegg Posted September 17, 2012 Share Posted September 17, 2012 the red FWD will not light up if the duty c is bad. and the fuse will not correct torque bind if the duty c is bad. both of these are a test to see if the duty c is bad. your duyt c is bad. Link to comment Share on other sites More sharing options...
Stang70Fastback Posted September 17, 2012 Share Posted September 17, 2012 I think what he is trying to say is that your duty c is bad. Link to comment Share on other sites More sharing options...
SBT Posted September 17, 2012 Share Posted September 17, 2012 i'd guess that the duty C is bad... Check with Brok in the second gens. He just went through a replacement on one of his IIRC. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
