taylormac1993 Posted September 9, 2012 Share Posted September 9, 2012 I recently rebuilt my EJ25D due to the HGs being bad. After I was finished and started it up, a code P0443 showed up. I tried letting the car equalize and drive it for a while, then erased the code. I also tried replacing the gas cap and erasing the code. But it couldn't be that easy... It keeps coming back. Any ideas on what this might mean? There's some kind of $200 fuel filter module that I could replace, but I don't have more than $1 to work with. I'm pretty sure all of my vac lines are good, but if there are a couple that get mixed up easily you guys should let me know. This is my first rebuild on a Subie engine and only my second rebuild ever. Link to comment Share on other sites More sharing options...
DOHCEJ22E1 Posted September 9, 2012 Share Posted September 9, 2012 What does the code describe? Is it an EVAP code? Link to comment Share on other sites More sharing options...
Baddog Posted September 9, 2012 Share Posted September 9, 2012 Check for a blue clip under the intake manifold. There is an Evap connector under there. Check all your connections. Passenger side. Link to comment Share on other sites More sharing options...
taylormac1993 Posted September 9, 2012 Author Share Posted September 9, 2012 What does the code describe? Is it an EVAP code? P0443 - "Evaporative Emission Control System Purge Control Valve Circuit" http://www.obd-codes.com/p0443 Check for a blue clip under the intake manifold. There is an Evap connector under there. Check all your connections. Passenger side. Will it be visible without taking anything off? Is it toward the front or back of the engine? Link to comment Share on other sites More sharing options...
johnegg Posted September 9, 2012 Share Posted September 9, 2012 ''circuit'' usually indicates an electrical problem, wire or connector. Link to comment Share on other sites More sharing options...
taylormac1993 Posted September 11, 2012 Author Share Posted September 11, 2012 Check for a blue clip under the intake manifold. There is an Evap connector under there. Check all your connections. Passenger side. That did it! No more code, check engine light is off. Thanks! I can't believe I missed that clip... Link to comment Share on other sites More sharing options...
