subaruguy509 Posted August 26, 2012 Share Posted August 26, 2012 I keep getting this trouble code, but don't know what it means. I reset the check engine light, but it comes back every once in a while. 42 "Idle switch Abnormal voltage input entered from idle switch Judges OFF operation" Link to comment Share on other sites More sharing options...
monkeyposeur Posted August 27, 2012 Share Posted August 27, 2012 Try bbs and report back! Link to comment Share on other sites More sharing options...
mnstrmech Posted September 1, 2012 Share Posted September 1, 2012 from alldata... The throttle position sensor contains both a potentiometer (variable resistor) and an idle switch. The ECU uses these signals to adjust air/fuel ratio during acceleration, deceleration and idle. LOCATION The throttle sensor is mounted to the throttle body in the engine compartment. OPERATION The sensor sends the ECU a potentiometer output signal corresponding to throttle valve opening. The idle switch signal only turns "ON" when the throttle is near idle position. basically, your throttle position sensor is crapping out.... Link to comment Share on other sites More sharing options...
subaruguy509 Posted September 2, 2012 Author Share Posted September 2, 2012 Do you have a picture of where it is? I couldn't seem to find anything similar to it. Link to comment Share on other sites More sharing options...
mnstrmech Posted September 3, 2012 Share Posted September 3, 2012 the throttle position sensor, or TPS is located on the throttle body, directly across from where the throttle cables connect to. i dont happen to have a pic though.... Link to comment Share on other sites More sharing options...
subaruguy509 Posted September 3, 2012 Author Share Posted September 3, 2012 To the left or the right of the cables? Link to comment Share on other sites More sharing options...
