ilya124 Posted August 25, 2012 Share Posted August 25, 2012 Hey everyone. I have a 2008 legacy 2.5i 5 speed. Sometimes when I shift and let the clutch out there's a metallic clink. Sometimes it doesn't happen ii get on the gas right aay,but I don't there's a clink. Btw car and clutch have 93k miles. Should I be worried? Thanks Link to comment Share on other sites More sharing options...
Max Capacity Posted August 27, 2012 Share Posted August 27, 2012 If this was a old RWD car, I'd say a U joint was going. This could be a CV joint, does the front end make a clicking noise when you turn in a tight circle ? Either way ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
ilya124 Posted August 28, 2012 Author Share Posted August 28, 2012 If this was a old RWD car, I'd say a U joint was going. This could be a CV joint, does the front end make a clicking noise when you turn in a tight circle ? Either way ? Nope theres only a clink when letting the clutch out. It's like the clutch is hitting a metallic part Link to comment Share on other sites More sharing options...
