94legacy22 Posted August 23, 2012 Share Posted August 23, 2012 im thinking about selling my 94 sedan legacy l AWD. 5-speed... I need a bigger car. I have a 99 escalade but dont want the mpg of it. thinking of getting a p-71 crown vic.. if anyone is intrested let me know. i'm thinking about 2,000 for it or bo. I have replaced 4 tires michelin mxv4,rims(used wrx) 4 new struts(kyb) both front axles are new. all fluids have been changed. new subaru oem t-belt, waterpump and thermostat. new battery, new alternator. brakes are fine 12k on fronts 8k on rears. new junkyard a/c compressor. a/c ice cold now. new belts(oem) uses about half quart about 800 miles or so. no leaks i fixed them(valve covers) could use motor mounts from being oil soaked. slight leak from rt exhaust manifold. its cracked could be rewelded. I had a receite from previous owner that clutch was replaced at 80k but i cant find it now. but it works fine. It runs great. gets 27mpg on highway. 146k miles. Im from mass so the closer you live the better. its got slight surface rust in 3 small spots the under carrage is near perfect. you will be supirsed to see it. I will put up some pics later when i put it on a lift. Its from oregon so thats why it has no rust on it. all surface rust spots is from scrapes that were not taken care of from previous owner. Link to comment Share on other sites More sharing options...
94legacy22 Posted August 24, 2012 Author Share Posted August 24, 2012 heater core hose just sprung a leak on me today... subaru part only. ordered today be in tuesday... Link to comment Share on other sites More sharing options...
