LegaLude Posted August 14, 2012 Share Posted August 14, 2012 I've come into the possession of 225/45/17's When testing fitment of the new wheels I turned in a manner that shifted the weight and a small portion of the tire rubbed the wheel well. I know that there is a common problem with the saggy butts. Originally I was looking into stiffer springs, because I figure the shocks are decent. Although I was suggested to save my money for coilovers and just drive nicely until then. Any other suggestions or ideas? Link to comment Share on other sites More sharing options...
.Catalyst. Posted August 14, 2012 Share Posted August 14, 2012 Not so sure you need COs. I don't want them for my DD at all. A good strut/spring combo will be better for street performance and comfort compared to most budget friendly COs. Unless of course you are going for extreme low or stance I say stick with strut/springs. Bilstein HD or Konis with pinks or epics are well reviewed here. My spec.B [#163] Project Thread with Pictures Get CryoTuned! Link to comment Share on other sites More sharing options...
Drift Motion Posted August 14, 2012 Share Posted August 14, 2012 what's the wheel spec? You can also roll the fenders to avoid rubbing. Link to comment Share on other sites More sharing options...
LegaLude Posted August 15, 2012 Author Share Posted August 15, 2012 It is a 35 offset. I'm not sure what all the specs might be. I have only just become aware of some of the technicalities that encompass wheels :/ I thought to roll the fenders, except that I've never personally done it or had it done to one of my cars. I'll definitely look into the strut/spring assembly. My only concern being how much a setup might lower the car. I had glanced at some Tein H tech springs since their height reduction is minimal. As well as those spacers for the rear assemblies; although I don't know if it'll make much difference. I'm not sure how much the spring/strut compressed in order to lift the tire into the wheel well like that. Maybe 4 inches. Not sure if the pics will help much, but these are the ones I got just after we tested the fitment, and they came right back off. Also, someone mentioned to me something about a negative camber bolt? I usually don't mess with all those settings. Link to comment Share on other sites More sharing options...
