08LGT80 Posted August 12, 2012 Share Posted August 12, 2012 Hi everyone, Today my check engine light, information display under the tachometer, and airbag light suddenly came on! There is no difference in handling and performance while driving! Has anyone experience this before? Thanks in advance! Link to comment Share on other sites More sharing options...
iNVAR Posted August 12, 2012 Share Posted August 12, 2012 pull the check engine code... what's wrong with you, sheesh. Link to comment Share on other sites More sharing options...
08LGT80 Posted August 13, 2012 Author Share Posted August 13, 2012 what do u mean pull the engine code? Link to comment Share on other sites More sharing options...
08LGT80 Posted August 13, 2012 Author Share Posted August 13, 2012 pull the check engine code... what's wrong with you, sheesh. i'm not a car expert Link to comment Share on other sites More sharing options...
ibr_adam09 Posted August 13, 2012 Share Posted August 13, 2012 Go to Auto-Zone and borrow their obd2 scanner. Use it to read the code using the obd port under the driver knee panel. Tell us what the code is.. Link to comment Share on other sites More sharing options...
08LGT80 Posted August 13, 2012 Author Share Posted August 13, 2012 code p2096 got several possibilities but nothing definite. he said the car is running lean, air/fuel ratio low, plugged converter, and failed post h02s Link to comment Share on other sites More sharing options...
iNVAR Posted August 13, 2012 Share Posted August 13, 2012 https://www.google.com/webhp?&q=p2096+site:legacygt.com You're right, lots of possibilities. You got some work to do. I'm not trying to be a jackass or anything, but there really are a lot of possibilities and you're going to have to work on narrowing things down. I'd start with checking for an exhaust leak first. Link to comment Share on other sites More sharing options...
laramieskibum Posted August 14, 2012 Share Posted August 14, 2012 02 sensor...? Link to comment Share on other sites More sharing options...
08LGT80 Posted August 15, 2012 Author Share Posted August 15, 2012 that's what i was thinking as well. since it was running lean, i just added a bottle of fuel system cleaner in my gas tank and went for a drive. a few mins later, the CEL disappeared. Link to comment Share on other sites More sharing options...
Max Capacity Posted August 15, 2012 Share Posted August 15, 2012 P2096 Post Catalyst Fuel Trim System Too Lean Bank 1 This is from the warrenty forum sticky here, http://legacygt.com/forums/showthread.php/trouble-codes-cels-26113.html I believe bank 1 is the front O2 sensor. Someone else just posted about replacing the front O2. There are easy to do. Pull the right front tire, reach in the panel and R&R the sensor. I got mine for around $120 bucks from Car Quest auto parts. I paid $80 for my rear O2. Just a thought, what brand gas do you use ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
08LGT80 Posted August 15, 2012 Author Share Posted August 15, 2012 chevron 92 octane Link to comment Share on other sites More sharing options...
