where to buy valve shims
If you have a way to measure their diameter (not thickness) in mm, you can search on Google and find out which Japanese motorcycle uses that diameter.
For example; the Yamaha made engine in the Ford Taurus SHO from 1989 through 1995 uses the same 29mm shims as Yamaha (of course) and several other bike makers. Be careful in your measurements though; if the Subie's are 20 mm do not buy anything even if just a half mm larger or smaller, they are meant to not move around in the bucket at all but still rotate.
Tom
