Zac88 Posted August 11, 2012 Share Posted August 11, 2012 I purchased a spec stage2+ clutch from a member here that said its for a 06 wrx, I couldnt see any part numbers on it so I assume its the right one? He did not send me the clutch alighnment tool is this a problem? Can I order another one?? Also can I use any wrx flywheel from any year? What about lightweight? Do I need special flywheel bolts for single mass? Link to comment Share on other sites More sharing options...
snowdrift86 Posted August 12, 2012 Share Posted August 12, 2012 I know you cant use early wrx flywheels because they used to have pull style clutches. I dont remember which year they switched to push style like ours, and then there was a year or two where they did dual mass like us. Pretty much if that clutch kit was meant for single mass and push style you can use an 07+ 5spd flywheel out of an LGT or WRX Link to comment Share on other sites More sharing options...
Zac88 Posted August 12, 2012 Author Share Posted August 12, 2012 oh no I bought a 06 wrx clutch and flywheel Link to comment Share on other sites More sharing options...
snowdrift86 Posted August 13, 2012 Share Posted August 13, 2012 Don't panic yet. When i was purchasing my single mass setup my dealership tried to tell me that it was half year thing? So. check the part numbers and verify it will work before you call it quits man Link to comment Share on other sites More sharing options...
iNVAR Posted August 13, 2012 Share Posted August 13, 2012 It's an 06+ WRX flywheel, sheesh. http://www.fredbeansparts.com/subaru-oem-single-mass-flywheel.html Link to comment Share on other sites More sharing options...
compsurge Posted August 13, 2012 Share Posted August 13, 2012 Pretty sure you need the spec flywheel with the spec clutch... Link to comment Share on other sites More sharing options...
GTTuner Posted August 13, 2012 Share Posted August 13, 2012 Spec offers a clutch for the dual mass set up on the LGT, however if you do not replace it it will chatter, IIRC you cannot resurface a DM flywheel. My personal opinion (from my experience) is the spec works well but doesn't last. I have 40K on my Spec stage 2 and its slipping. I got more mileage out of my OE clutch and I abused that one more that this Spec, believe it or not. Link to comment Share on other sites More sharing options...
iNVAR Posted August 13, 2012 Share Posted August 13, 2012 Pretty sure you need the spec flywheel with the spec clutch... I don't even see a Spec flywheel listed here: http://www.fredbeansparts.com/all.html?subaru=272&search=View+Products&cat=23 Not that that's conclusive, but if FBP is selling the spec clutch kit and a spec flywheel were required, they would almost assuredly tell you in the description, and they'd offer a package deal, and at the very least, they'd have it listed somewhere. Link to comment Share on other sites More sharing options...
Zac88 Posted August 13, 2012 Author Share Posted August 13, 2012 I ordered a spec flywheel for 06 wrx fitment. Apparently this combo will work as long as I get 06 wrx flywheel bolts. Also ordered the TSK3 Snout repair week. Link to comment Share on other sites More sharing options...
compsurge Posted August 13, 2012 Share Posted August 13, 2012 Max Capacity is by far the expert on spec clutches I think I was thinking about Competition Clutch (which DOES require the Competition Clutch LWFW with the Clutch) Link to comment Share on other sites More sharing options...
Max Capacity Posted August 13, 2012 Share Posted August 13, 2012 I ordered a spec flywheel for 06 wrx fitment. Apparently this combo will work as long as I get 06 wrx flywheel bolts. Also ordered the TSK3 Snout repair week. Checking in, You should be fine with the 06 wrx FW, it should use oem FW hex head bolts. My Spec LWFW that I bought when I bought the Spec 2+ clutch (back in Jun07) uses OEM DMFW bolts which are the Torx Plus 50 bit, which you can get the bit from Fredbeans as well as the hex head bolts. You can also go to Spec's website and order a alignment tool, if you can't find it, call them. Your not that close to me, or I'd let you borrow mine. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Zac88 Posted August 13, 2012 Author Share Posted August 13, 2012 Will I need a spec specific alignment tool? And I'll need to order wrx flywheel bolts? Link to comment Share on other sites More sharing options...
Max Capacity Posted August 13, 2012 Share Posted August 13, 2012 I'm guessing yes to both questions. It will be much easier to line up the splines for the tranny with the tool. Without it, it's a crap shoot. You don't want to reuse the torx plus bolts if you don't have too. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Zac88 Posted August 15, 2012 Author Share Posted August 15, 2012 ok so I will have to find torx plus bolts then. Are you running the spec dual mass flywheel or single mass? Link to comment Share on other sites More sharing options...
Cannonball-44 Posted August 16, 2012 Share Posted August 16, 2012 You will need to get a torx-plus bit to remove the bolts on your flywheel. What is recommended then is to use the WRX (normal hex) bolts and do not reuse the torx plus. In the process of doing the clutch in my LGT right now so have just finished researching this to death. Went with a CM-300 and WRX single mass fly wheel. Link to comment Share on other sites More sharing options...
compsurge Posted August 16, 2012 Share Posted August 16, 2012 ok so I will have to find torx plus bolts then. Are you running the spec dual mass flywheel or single mass? Max is running the single mass Spec aluminum LWFW with the replaceable insert Link to comment Share on other sites More sharing options...
Zac88 Posted August 16, 2012 Author Share Posted August 16, 2012 You will need to get a torx-plus bit to remove the bolts on your flywheel. What is recommended then is to use the WRX (normal hex) bolts and do not reuse the torx plus. In the process of doing the clutch in my LGT right now so have just finished researching this to death. Went with a CM-300 and WRX single mass fly wheel. Hey I live in Edmonton too! Most likely getting Apex to do my clutch. So I'll need WRX specific flywheel bolts then? Link to comment Share on other sites More sharing options...
Cannonball-44 Posted August 16, 2012 Share Posted August 16, 2012 Sent you a PM. Link to comment Share on other sites More sharing options...
Max Capacity Posted August 16, 2012 Share Posted August 16, 2012 Hey I live in Edmonton too! Most likely getting Apex to do my clutch. So I'll need WRX specific flywheel bolts then? Yes. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
legacyjohn Posted August 16, 2012 Share Posted August 16, 2012 here is a link to a exedy conversion kit has everything you need bare the flywheel bolts http://www.ebay.com/itm/EXEDY-CLUTCH-KIT-SET-FF502-RACING-FLYWHEEL-IMPREZA-WRX-LEGACY-GT-2-5L-TURBO-/150861073479?fits=Model:Legacy&hash=item2320054c47&item=150861073479&pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr#ht_3381wt_1139 Link to comment Share on other sites More sharing options...
Zac88 Posted August 17, 2012 Author Share Posted August 17, 2012 Im looking everywhere for 06 wrx flywheel bolts no luck yet Link to comment Share on other sites More sharing options...
Zac88 Posted August 17, 2012 Author Share Posted August 17, 2012 Flywheel, Bolt PT190301 BOLT 10x24.5x17 -2.5 liter turbo Found that on SGP under 2006 impreza is that the bolt I need? Also 8 in total correct? Link to comment Share on other sites More sharing options...
compsurge Posted August 18, 2012 Share Posted August 18, 2012 You can reuse the OEM bolts. It doesn't make a difference - the WRX are hex bolts and can use a standard socket to remove or install. The torx bolts aren't as hard as everyone makes them out to be for getting off. Find a bit and use a screwdriver to hold the flywheel in place while you unbolt them. I loctite (blue) and torque them to the appropriate torque value. I believe it is 53 ft-lb. Link to comment Share on other sites More sharing options...
Zac88 Posted August 18, 2012 Author Share Posted August 18, 2012 I was under the impression dual mass and single mass bolts are different? Link to comment Share on other sites More sharing options...
compsurge Posted August 18, 2012 Share Posted August 18, 2012 The head is, but either can be used. I'm running torx from my dual mass on a single mass now. They are torx on the dual mass so the head of the bolt fits in the deeper flywheel of the dual mass. Link to comment Share on other sites More sharing options...
