SomethingWittyAsAUsername Posted August 9, 2012 Share Posted August 9, 2012 My wheels are stuck. No matter what I do, my wheels will not come off the car. Lug nuts come off, but these steelies weld themselves to the rest of the car every time, so I can't get anymore work done. Any suggestions? Link to comment Share on other sites More sharing options...
BDII Posted August 9, 2012 Share Posted August 9, 2012 rubber mallet Need forum help? Private Message legGTLT Link to comment Share on other sites More sharing options...
captainobvious Posted August 9, 2012 Share Posted August 9, 2012 PB blaster Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted August 9, 2012 Moderators Share Posted August 9, 2012 block of wood and a mini sledge. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
Stasis Posted August 9, 2012 Share Posted August 9, 2012 River Link to comment Share on other sites More sharing options...
travgag Posted August 9, 2012 Share Posted August 9, 2012 some pb blaster and a mini or large sledge should do it. Dont hit the rim tho and then i always put some anti-seize and you'll never have that problem again, i use permetex copper stuff Link to comment Share on other sites More sharing options...
BAC5.2 Posted August 9, 2012 Share Posted August 9, 2012 Sawzall. And put antisieze on the hub next time. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted August 9, 2012 Moderators Share Posted August 9, 2012 Sawzall. And put antisieze on the hub next time. Wat? "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
whitetiger Posted August 9, 2012 Share Posted August 9, 2012 TNT. blast it off. Link to comment Share on other sites More sharing options...
BAC5.2 Posted August 9, 2012 Share Posted August 9, 2012 Wat? Not hub. Rotor. Put anti-sieze where the wheel contacts the rotor. Wheels won't stick, that way. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted August 9, 2012 Moderators Share Posted August 9, 2012 I was "wat"-ing at the sawzall part... "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
johnegg Posted August 9, 2012 Share Posted August 9, 2012 you can try this, loosen all the lug nuts just a little, maybe only do one wheel at a time, and then go for a spirited drive until the wheel starts making noise. just a thought. Link to comment Share on other sites More sharing options...
BAC5.2 Posted August 9, 2012 Share Posted August 9, 2012 you can try this, loosen all the lug nuts just a little, maybe only do one wheel at a time, and then go for a spirited drive until the wheel starts making noise. just a thought. Just doing a figure 8 in a parking lot will suffice. I've done it. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
JJay03 Posted August 10, 2012 Share Posted August 10, 2012 you can try this, loosen all the lug nuts just a little, maybe only do one wheel at a time, and then go for a spirited drive until the wheel starts making noise. just a thought. I hope your joking lol. Rubber mallet and try spraying some pb blaster where the wheel contacts the rotor. I always put antiseize on the rotor also like others said. Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted August 10, 2012 Moderators Share Posted August 10, 2012 Just doing a figure 8 in a parking lot will suffice. I've done it. This is truth. Have a friend watch your wheel as you roll--if they're a good friend they'll surely tell you when to stop "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
travgag Posted August 10, 2012 Share Posted August 10, 2012 i like the idea if doing figure 8's Link to comment Share on other sites More sharing options...
taylormac1993 Posted August 10, 2012 Share Posted August 10, 2012 Tie all 4 of your rims to 4 different trucks. Then have a fat kid sit in it while they pull the rims off. Link to comment Share on other sites More sharing options...
johnegg Posted August 10, 2012 Share Posted August 10, 2012 only slightly. figure 8s sound way better than a spirited drive. but the point is you need to add enough force to loosen the wheel. and i have driven on a wheel with lug nuts i forgot to tighten and it is immediately apparent. especially if you are listening for it. so there isn't much chance you are going to foul up anything to a great degree. you just want to use enough force to break it loose. driving may be more than you need, but if you have spent all afternoon working on it, why not try. Link to comment Share on other sites More sharing options...
SpecBamf41 Posted August 10, 2012 Share Posted August 10, 2012 I drove around 3 day wondering what a noise what. I figured it out when my rear tire fell off. I put it back on and drove out of the ditch. Sent from my Galaxy Tab using TapaTalk 2 BNR18g on 93oct Link to comment Share on other sites More sharing options...
Jippi Posted August 10, 2012 Share Posted August 10, 2012 what you can try is to loosen all your lugs half way and drive in reverse or forward real fast down the driveway adn slam on the brakes and they should pop off the hubs. when my brothers rav4 and sisters galant both with steelies had wheels stuck and once i slam on the brakes it was a non issue.. good luck Link to comment Share on other sites More sharing options...
travgag Posted August 10, 2012 Share Posted August 10, 2012 haha Swagon, thats funny ! Link to comment Share on other sites More sharing options...
GTTuner Posted August 10, 2012 Share Posted August 10, 2012 you can try this, loosen all the lug nuts just a little, maybe only do one wheel at a time, and then go for a spirited drive until the wheel starts making noise. Just a thought. this! Link to comment Share on other sites More sharing options...
PeterJMC Posted August 10, 2012 Share Posted August 10, 2012 LoL at all the suggestions he play in traffic with loose lug nuts Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted August 10, 2012 Moderators Share Posted August 10, 2012 Don't do ANYTHING "spirited" or "fast" with your lug nuts loose, that's retarded. Just do slow, controlled figure 8's in a parking lot. You'll be safe and the wheels should come right off without falling off completely. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
SpecBamf41 Posted August 11, 2012 Share Posted August 11, 2012 Hell. Lossen them all 2-3 turns. Drive 10 feet and stomp on the brakes. Sent from my Galaxy Tab using TapaTalk 2 BNR18g on 93oct Link to comment Share on other sites More sharing options...
