JFB Posted August 9, 2012 Share Posted August 9, 2012 Hey guys, So I did search around a bit but this seems to be a pretty ambiguous CEL and I was hoping someone might have some firsthand experience to share on our generation of Legacy, or at least help me figure out what I need to do to follow some stuff I did find. The basics: Error Code P0122 Definition: Throttle/pedal position sensor/switch "A" circuit - Low input Probable Causes: Open or Short Circuit ConditionPoor Electrical ConnectionFaulty IP SensorFaulty APP Sensor So it seems to be kind've ambiguous. I've got no idea what an IP Sensor or APP Sensor are so some help in that would be nice. I'm not real sure how I would figure out if I've got an Open or Short Circuit, same for Poor Electrical Connection. I did find something about cleaning out the throttle body in my searching sometimes fixing this issue, but I can't seem to find my Haynes Manual, and I'm a real newbie to trying to do engine work myself, very willing to learn, but I've got no idea what a throttle body is or where it might be hidden. Another issue that may or may not be related to this engine code, I'd certainly never noticed it before today, but my windshield washer pump seemed to lack power, and the wipers themselves were very sluggish, so much so that at one point I had to pull back on my wiper arm to keep sending the signal to run the wiper (single run thing) until the blades finally made it and reset back into their slots. Oddly after I stopped at Auto Zone to have my code read, they seemed to be working okay again and I refilled the fluid just in case. I can't imagine both the pump for the fluid and the blade motors would fail at once so I'm hoping someone has some ideas on this too, and if it might be related! I'd love to fix this myself if possible and avoid taking it to my mechanic. Link to comment Share on other sites More sharing options...
monkeyposeur Posted August 9, 2012 Share Posted August 9, 2012 Part of your throttle body is a disc that is inside your intake manifold. That is what gets all dirty and gunked up. Follow your air intake from the passenger side to the top of of your intake manifold where the air intake clamps on. Pop it off and clean it out with throttle body cleaner. You can also identify it by the two cables that attach to it. There is a spring and a few cables that look like bicycle brake cables. If you press on it it revs the engine. Link to comment Share on other sites More sharing options...
JFB Posted August 9, 2012 Author Share Posted August 9, 2012 Part of your throttle body is a disc that is inside your intake manifold. That is what gets all dirty and gunked up. Follow your air intake from the passenger side to the top of of your intake manifold where the air intake clamps on. Pop it off and clean it out with throttle body cleaner. You can also identify it by the two cables that attach to it. There is a spring and a few cables that look like bicycle brake cables. If you press on it it revs the engine. So I gave up trying to find a EJ25 photo and settled for a photo of someone's engine bay that seems to have all of the important features of mine. http://memimage.cardomain.com/ride_images/1/2857/4801/7142400009_large.jpg So if I understand this correctly, where the black box with subaru stamped into the top that's attached by a compressible hose to the air filter box attaches to the metal is what I'm looking for? If I clean it out (how would I do so anyhow?) how would I go about resetting the CEL to see if that solved the problem? Link to comment Share on other sites More sharing options...
twisty Posted August 9, 2012 Share Posted August 9, 2012 If I clean it out (how would I do so anyhow?) how would I go about resetting the CEL to see if that solved the problem? usually, once you fix an issue and drive it a bit the codes will go away naturally. otherwise, go to a shop that will check the codes for free and see if they will clear them. autozone and oreilly here are not allowed to clear the codes anymore. thats why i got my own scanner, hehe. Link to comment Share on other sites More sharing options...
twisty Posted August 9, 2012 Share Posted August 9, 2012 So if I understand this correctly, where the black box with subaru stamped into the top that's attached by a compressible hose to the air filter box attaches to the metal is what I'm looking for? yes, that shiny tube like thing between the black box and the spark plugs is the throttle body Link to comment Share on other sites More sharing options...
JJay03 Posted August 10, 2012 Share Posted August 10, 2012 Ide say your tps is prob dieing. The sensor on the left side of the throttle body. I never heard of a dirty throttle body throwing a code for tps voltage?? When they go bad they get dead spots if you watch a graph it wont be smooth. Link to comment Share on other sites More sharing options...
JFB Posted August 10, 2012 Author Share Posted August 10, 2012 So I did nothing and it went away on its own. What's a TPS Sensor go for? Link to comment Share on other sites More sharing options...
JJay03 Posted August 10, 2012 Share Posted August 10, 2012 So I did nothing and it went away on its own. What's a TPS Sensor go for? One from subaru is 90-100. Link to comment Share on other sites More sharing options...
JFB Posted August 10, 2012 Author Share Posted August 10, 2012 One from subaru is 90-100. Super. New paint job gets further and further away. Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted August 11, 2012 I Donated Share Posted August 11, 2012 what is IP and APP? -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
